Old 11-07-2010, 05:25 AM
Pasz Pasz is offline
Default MC Control touch screen misreads coords of press
This happens often, but not all the time. Not sure if it's a hardware or software problem. Anybody else has this?
Is there a way to calibrate the screen or something?
Old 11-07-2010, 07:30 AM
zeeman zeeman is offline
Default Re: MC Control touch screen misreads coords of press
same here.
did not do this till the latest update.
zeeman
Old 11-08-2010, 03:11 AM
Originally Posted by zeeman View Post
same here.
zeeman
So it's probably a software bug? Are more people having this problem?
If so, AVID/EUPHONIX please fix this because this pretty much makes the MC Control unusable for us (for me at least anyway).
Old 11-08-2010, 03:12 AM
Zeeman, are you using v1 too?
Old 11-08-2010, 06:40 AM
Yep V1 over here.
really disappointed with this update.
lost so much control that i used to have.
the only reason i did the update was for ucon.
zeeman
Old 11-08-2010, 08:25 AM
I hope Euphonix/Avid is reading these posts and provides bug fixes soon.
Old 11-09-2010, 06:57 AM
Artist PM's Avatar
Artist PM Artist PM is offline
Hi guys,
There is a way to recalibrate your touchscreen. Have either of you contacted customer success? If you have, and your case is not in progress, please email me directly at john.haydon@avid.com.
Regarding softkeys on the MC Control: These are regulated by an xml file that you can edit with the EuControl softkey editor. Feel free to post requests about your customized appsets and what you'd like to see in the default!
Best,
JC
Old 11-09-2010, 06:10 PM
DigiTechSupt's Avatar
It is very easy to calibrate your touchscreen:
1. Power down your MC Control.
2. Press down the "bank left", "bank right", and the "nudge right" buttons on the right hand side of the MC Control simultaneously.
3. Power on the unit (with the 3 buttons still pushed)
4. You will enter into test mode.
5.Touch your touchscreen
From here, you can calibrate your touchscreen. We suggest you use an object with a precise point for a more accurate calibration but not a pin or anything that's sharp enough to mar the surface.
Avid Audio Tech Support
Support FAQ
Old 11-09-2010, 07:34 PM
Venture Studios Venture Studios is offline
Yep V1 over here.
Couldnt agree more. This update was pretty bad. Don't get me wrong I love having Eucon supported but we've lost so much that im gonna have to run in HUI until another update. John could we please get some of the soft key commands back like solo clear, copy/paste plugin settings those are the ones ive noticed so far but there's definitely a lot missing that used to be there. Also the fact that quick punch doesn't work is such a huge over sight I don't know how a release was made without it working. Im sure you guys are working hard, hopefully we can get a new release quickly.
Old 11-10-2010, 02:44 PM
We're working on a reimplementation of the app set to bring back some of the HUI-like configurations that you've been used to.
Support FAQ
2.6.1 Rotary Encoder Issues, and MC Control Touch Screen Freeze anotherchrisperry Artist Series 12 05-04-2012 02:45 AM
Artist Control V1 Touch Screen Xill Artist Series 3 08-19-2011 02:52 PM
Touch to select on MC mix, does control touch screen follow? Led Artist Series 0 03-24-2011 06:36 AM
Touch Screen JMS40 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 7 01-28-2004 03:38 PM
Touch Screen Control Surface? joy4u Tips & Tricks 2 11-30-2001 02:30 AM
