Re: 11r eleven rack window gone disappeared missing vanished POOF! (and no midi input
You should install all your programs to the OS drive.
Brian Windows 11 Pro | macOS 12 Pro Tools 2022 benonistudio.com Youtube Channel - benonistudio Plugin Deals @benonistudio |
considering my 11r gui is gone, do you think 2gb ram upgrade on an hp pavilion a530n w/ a 2ghz amd 64 athlon and windows xp 32 bit would run PT 8.05 le ? cuz the 1gb isnt cutting it.
hey benoni
i put it on the partition cuz it was originally on the OS and it wasnt working so i thought the partition might freshen things up. the third restinall on the OS didnt work either. thanks for the reply |
You are having so many problems, im starting to think you just need to wipe the drive completely and start over with a fresh OS install, ect.. ect..
i think ur right. thanks for tryin
#16
oh u forgot to tell me: do you think 2gb ram on an hp pavilion a530n w/ a 2ghz amd 64 athlon and windows xp 32 bit would run PT 8.05 le ? cuz the 1gb isnt cutting it.
#17
(i just checked Crucial and it appears that its not even DDR2 its DDR) Its an AMD chip. Intel is better for PT. That model was introduced in 2004. 8 years is a LONG time for a computer. The chipset is nVidia. Not good, Intel Chipset is what you want (dont confuse nVidia chipset with nVidia Video processor) On the HP site it says the max supported Ram is 1GB. http://h10025.www1.hp.com/ewfrf/wc/d...product=404646 Looking on Crucial it says the max ram is 2GB with DDR PC2700, DDR PC3200 with a maximum of 1GB per slot. http://www.crucial.com/store/listpar...vilion%20a530n DDR is old. DDR3 is the standard these days. Windows XP is dead and will not be supported in future PT versions. So taking all of that into consideration, I would say dont waste the money on Ram. save up and build a new PC, buy a new PC that meets or exceeds the requirements from Avid, or buy a mac that meets or exceeds the requirements from Avid. thats my opinion.
#18
just thought of something else, make sure you have Quicktime installed, thats helped me before with the 11R Editor when using the Eleven Rack on pc's that are not up to snuff with the requirements.
#19
thank you very much sir, your thought and consideration is greatly appreciated. i dont have quicktime actually, so i will get that installed today. the laptop matter is now closed.
on another note, just to let you know, idk if u recall, but I had ordered the ram last week (when i started this thread). you are right, crucials site and asus site both said 2gb max, and I got a great, unbeleivable deal from PNY for 2x 1gb pc2700 ddr1 sdram dimm modules, so since I bought it already and I cant return it, Ill just give it a shot and see how it works and tell you. however, im going to do what you said, custom build a windows 7 PC for PT 8 le. please tell me what specs you recommend: -intel mobo/chipset (which model? w/ built in or seperate gpu?) -intel processor (quad core? mhz speed?) -ddr3 (how many gb ram?) anything else i should be aware of? thanks for the suggestion, i think its a good investment anyway for the next 7 years or so |
#20
This happened to me. No midi, no 11 rack window.
I did a completely fresh install of windows on a new drive, and poof. It was fixed. Benoni and I were stumped when this happened in 2010 Nick
Core i7 920 OC'ed @ 4.0 GHz (200 X 20) 12 GB Patriot Viper Extreme Asus P6T OCZ Agility 64 GB SSD Hitachi 1TB 32 MB HDD WD Caviar Black 500GB Saphhire HD 5850 3 x 20" monitors Eleven Rack w/ ERXP Fender Super Champ XD Marshall JCM2000 DSL100 Silver Edition W/ Silver Jubilee Cabinet |
10.3.6 = No Eleven Rack Window? | brianiac5150 | Eleven Rack | 23 | 08-21-2013 02:59 PM |
Eleven Rack - Can MIDI CC be used to select rig input | adamqlw | Eleven Rack | 28 | 04-14-2013 09:15 AM |
Eleven Rack window responds to changes on Eleven Rack, unable to record. | pine | Eleven Rack | 6 | 08-02-2012 07:50 PM |
Eleven Rack and Eleven Rack control window not matching | 11R Newbie | Eleven Rack | 3 | 04-18-2012 06:07 PM |
Upgraded to PT 9, Eleven Rack Expansion pack disappeared! | AndersDM | macOS | 5 | 06-17-2011 12:36 PM |
