Old 10-07-2020, 06:29 PM
Panacci Panacci is offline
Default Weirdness with Mojave OS 14.6
Hey guys , I have two 2009 MacPro,s 5.1,s. They have the same video cards MSI Radeon 570,s. I installed 14.6 and all of a sudden I am getting errors with ProTools at 512 and higher. I also am using DP and getting errors with both programs running simple files. All is well in High Sierra for both. I then reinstalled Mojave 14.0, then .1, .2 ,.3 with no problems. When I loaded .4 ,.5 and .6 I got the errors again. I then tried just the Mac input and output and still got the errors. Can anyone shed light on this ? What would change in the system to cause the errors? This has me stumped, thanks !
Two 2009 8 Core Mac 5.1, (32 gigs Ram), MSI Radeon 570,s 2011 MacBookPro , 828MKIII Hybrid , 8Pre, OSX Mojave 14.3,High Sierra 13.6, DP10, MachV3, PT2020.9 Vanilla , Peak 7, Logic 9 ,WaveLab 10,Cubase Elements 10,Reason 10, DSP-Quattro 5 ,many plugins , mics and synths. http://www.panaccimusic.com
Old 10-07-2020, 06:34 PM
JFreak's Avatar
JFreak JFreak is offline
Default Re: Weirdness with Mojave OS 14.6
Find rhe combo installer that installs everytging since original dot-zero Mojave. It may solve your isaues. If it does not work, go baxk and find combo installer foe sot-theee which you dound to be working.
That machine is not supported so you may expect somwthing like rhis.
Janne
Old 10-08-2020, 05:50 AM
Thanks J, will look for a MacPro 2012 and up to move forward
Mojave 10.14.5 massivekerry macOS 48 04-10-2020 02:02 PM
OSX 10.14 Mojave milescoolin71 Pro Tools 12 2 07-03-2019 02:19 AM
Mojave or not Brian Hudson macOS 2 05-23-2019 10:35 AM
Mojave? hanksinclair Artist Series 3 05-03-2019 04:19 PM
Mojave ? Riquier macOS 89 02-26-2019 07:41 PM
