Old 04-09-2020, 06:44 PM
philip888's Avatar
philip888 philip888 is offline
Default Eleven Rack Driver Install FAIL
Windows 10
PT 12.7
I'm attempting to install the Install Avid Eleven Rack 1.1.11
When I click the installer the Windows Blue Circle shows up like its about to initiate and populate the next instruction window.
But it goes away and nothing happens.
I tried a Widows Tool https://support.microsoft.com/en-us/...led-or-removed
And no change.
Any ideas?
Thanks
Gigabyte EX58A-UD3R BIOS FH, Intel Core i7 CPU 980X, 24GB Mushkin Enhanced Blackline DDR3 1600Mhz PC3-12800, NVIDIA GeForce GTX 560, Windows 10 Pro 64 Bit, Pro Tools 12.7
Old 04-11-2020, 10:45 AM
philip888's Avatar
Default Re: Eleven Rack Driver Install FAIL
Any help would be appreciated.
Ive exhausted google.
Old 04-11-2020, 03:03 PM
What's the history of this OS install? Has the Eleven Rack been installed before?
Download a new copy of the installer
Uninstall the previous driver if it was installed before
Make sure the Eleven Rack is not connected.
Disable or uninstall all antivirus crapware.
Reboot
Try again.
I that still does not work... was this a clean install of Windows or an OEM install full of crapware. If the later grab a spare drive or partition and do a full clean install of Windows (hopefully Pro) from Microsoft, not an OEM recovery. You may need to purchase a new license. Install as little as possible, like any needed graphics drivers and try installing the Eleven Rack driver before worrying about Pro Tools or anything else. Get that fully running and clone over your current boot drive.
How do you uninstall the Eleven Rack Driver? ufoclub1977 Eleven Rack 6 10-23-2018 03:18 PM
El Capitan Eleven Rack Driver is HERE! guitaramundo Eleven Rack 1 01-15-2016 07:28 AM
Help! Driver install fail! Mbox 3 Pro - Not even showing up in Device Manager Ryan_Oceros 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 2 11-06-2012 03:38 PM
Driver install fail - Mbox 3 Pro not even showing in device manager Ryan_Oceros 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 0 11-01-2012 01:05 AM
