Old 06-04-2015, 08:16 PM
vio vio is offline
Default No sound, can't change I/O settings
Hey guys, I'm sure this is basic but I'm stuck. I just set up PT and there's no sound.
I'm using integrated sound with headphones (for now -- just getting started!). The PT default output is the Digital Audio (S/PDIF) High Definition Audio Device, so I tried to change it to my headphones. It asks if I want to Save/Close/Reopen but after reopening it still doesn't change.
I tried disabling the Digital Audio (S/PDIF) High Definition Audio Device in my PC sound settings, which actually gave me sound in PT but it was very distorted.
I have no idea what I'm doing. Help!
ProTools 12.0.0
Windows 8.1 Pro
Intel i5-4690 3.50GHz
16GB RAM
ASUS Z87 Sabertooth
Old 06-05-2015, 01:05 AM
Stig Eliassen's Avatar
Default
Welcome to these forums.
Press and hold the "N" key during launch of PT, and hold it until the Playback engine window opens. Are you able to select the preferred hardware?
Old 06-05-2015, 09:19 AM
vio vio is offline
Default
Thank you!
The hardware is visible. I select it and hit okay, but once PT fully launches it's reverted to the default option.
ProTools 12.0.0
Windows 8.1 Pro
16GB RAM
ASUS Z87 Sabertooth
Old 06-05-2015, 09:35 AM
Default
I see. I'll ask around. PC is not my strong side.
Old 06-05-2015, 10:18 AM
Southsidemusic's Avatar
Default
Hi and welcome
You need ASIO4ALL if you wanna use the internal sound device.
It's a software lots of people use when they wanna use the internal sound card so you can safely download and install it as even though the website looks like a "warez site" hehe
Download it here www.asio4all.com and install. Simple and works ... well it works
Best Regards
Christopher
#thestruggleisreal
South Side Music Group
WEBHOME
Old 06-05-2015, 10:36 AM
vio vio is offline
Default
Thanks for the welcome!
I'd installed ASIO4ALL before posting here, but when I tried to switch to it while Pro Tools was open I got the error "Assertion in "..\ ..\ Sys\ Win32\ Sys_FileLocWin32.cpp", line 550."
This deterred me but I gave it another shot and was able to get it working! I can only change it by selecting it before Pro Tools fully launches. Changing it with PT already open still gives the error.
Thank you so much! I'm frustrated it was such a simple fix but I'm glad to have it working
ProTools 12.0.0
Windows 8.1 Pro
16GB RAM
ASUS Z87 Sabertooth
Old 06-05-2015, 10:40 AM
Default
Great to hear.
Also I believe you can disable the windows soundcard so that Asio4all is chosen each time you start PT.
Worth a try as you don't need any workarounds when you have a song idea cooking and need to fire up the computer hehe
Good Luck and Thanks for reporting back.
Best Regards
Christopher
#thestruggleisreal
WEBHOME
Old 06-05-2015, 11:48 AM
Shan's Avatar
Shan Shan is offline
Default
If you're just monitoring and doing edits on a Surface/Laptop/Tablet etc, the new Windows Audio Device driver in PT 12 will suffice:
For recording, you'll need to use ASIO4ALL as mentioned by the others above.
Shane
Pro Tools Power User Editing
Give your plug-ins a facelift...and skin 'em!
"Music should be performed by the musician, not by the engineer."
Michael Wagener 25th July 2005, 02:59 PM
Pro Tools|HD Native 9.0.1 | Pro Tools|HDX 10.2 | Studio One | REAPER 4.22 | HD OMNI | HoboMac Pro 2.26Ghz Quad-Core | W7 Ultimate 64-bit
Old 06-05-2015, 12:01 PM
Amack Amack is offline
Default
ASIO4ALL (in conjunction with the computer's non-HDMI audio device) is the only PC audio device that I know of that works properly with PT12 (and 11?). See http://duc.avid.com/showthread.php?t=368422 for details. PT12 can't set the sample rate for its new "Windows Audio Device".
Shane
Old 06-05-2015, 12:38 PM
Shan's Avatar
Default
I haven't experienced those specific issues myself, but thanks for the detailed workaround. I bookmarked your post for reference.
It uses the global sample rate set up by the OS. You'll need to change it in Speaker Properties:
I'm sure we'll see this further developed by Avid down the road. It's their first implementation of this after all.
Shane
Eleven Rack doesn't change sound output when I change to a new rig Jlambton Eleven Rack 4 02-28-2011 11:51 PM
Change i/o Settings? shultzee13 Pro Tools M-Powered (Win) 0 07-14-2010 02:48 PM
Can Change IRQ settings in Bios Can't From within XP PRO TallCat 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 0 04-01-2003 06:42 AM
How do you change IRQ settings in XP Pro? Calvin 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 7 08-20-2002 12:48 AM
How do you change IRQ settings in WinME? geetarbill 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 2 06-09-2001 07:35 AM
