Play bug when updating to 8.0.3
Ok so when I was using PT 8 with no update, play was just fine, on 8.0.1 too.
Updating to 8.0.3 anyway if I zoom into a section (I zoom till I see on the grid each quarter note being long like 4 - 5 cm) and I hit play, the graphics (faders metering in general) are skipping some frames like there's a lot of work for the cpu, as soon as the cursor leaves the section I'm zooming, the faders metering animation are just fine, no frame skipping whatsoever. Of course is not just the faders metering animation being slow, is even slow if you tweak some parameters on plug-ins. It's strange because it doesn't happen with the other update. |
Notation view edit while in play cause play to stop working. | soybalm | Pro Tools 10 | 1 | 04-18-2013 11:11 AM |
Updating PACE drivers... before updating to 9.0.5 | lanstrad | Pro Tools 9 | 0 | 08-28-2011 07:37 PM |
play flashes then stops. session wont play. | hellbert | Windows | 21 | 03-31-2011 10:49 PM |
When press play the stop key lite and play key blinking | Sam Yin | Tips & Tricks | 6 | 12-05-2009 08:26 PM |
Updating HD7.2 to HD7.4. Will plugins need updating? | Ru_C | Pro Tools TDM Systems (Mac) | 4 | 08-14-2009 04:02 AM |
