hardware buffer issues on 6.4 LE with 001
Hey,
I am running 6.4 with a 001, as the title suggests, and I am having problems with the sample rate in the playback engine page. It has not been an issue before, but, for whatever reason, one song i am working on stops playing at about 3 minutes in, and tells me to lower the buffer size....so, i go and change it to 512 and try again, at the exact same point, it tells me to increase the buffer. So, I increase it, and the cycle of annoyance continues. It is getting to be an issue, as the band is waiting for copies, and i can't bounce the damn thing. any ideas? |
Re: hardware buffer issues on 6.4 LE with 001
Could be a bad file. Try "save session copy in" and tell it "copy audio files" then try opening the copy and bounce from there.
Also, you can usually find a bad file by creating a new blank session, then import each track one at a time and play through the spot where it hangs. One track'll usually make it hang. If neither works, to get you through, try consolidating the tracks. Ter |
thanks
Hardware buffer issues | cweber | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 1 | 03-07-2011 07:07 AM |
Increase Hardware Buffer Size? issues! PLEASE HELP! | ryanjones001 | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 16 | 05-01-2008 10:55 PM |
Importing Audio Issues and Buffer Issues PLEASE HELP! | sean scramble | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 10 | 05-19-2007 08:23 AM |
bfd lite hardware buffer issues | board724 | Virtual Instruments | 2 | 02-25-2007 10:06 AM |
Hardware buffer size in relation to DAE buffer | sricabla | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 2 | 06-04-2006 10:30 AM |
