Go Back   Avid Pro Audio Community > Legacy Products > Digidesign Hardware & Software
Old 10-05-2021, 08:37 AM
Default Re: some of my vocal audio tracks not playing back...help
Things to check:
1-are the tracks made inactive? Make them inactive and then active.
2-is the track muted or set to Input(the green I button)?
3-is the waveform itself muted(Ctrl+M click on a clip to mute and unmute).
4-is the waveform colored or grey(if grey, see 1 and 3)
5-change the track output to any stereo bus and then back to your main outs(I say stereo bus so you don't lose pan settings)
Old 10-12-2021, 01:59 AM
chrisdee's Avatar
chrisdee chrisdee is offline
Originally Posted by albee1952 View Post
Things to check:
+1.
And if the above doesnt help try creating a new session and import your tracks into the new session.
You might have to import one track at a time to see where the problem is.
This might also be caused by some buggy plugins as somebody already mentioned. So try removing any plugins you have on the track.
Christian D Hagen | I7 Builds | PT/OS Compability Chart
Old 11-19-2021, 08:19 AM
Indeed, it was suggested to bypass all plugins but did you actually try that? If Melodyne is on the tracks, open the Melodyne plugin(s) and see if the blobs are orange(good) or grey(missing).
Old 11-19-2021, 08:31 AM
Originally Posted by plevi1 View Post
Catalina, Protools 12 3.2020
What is that? PT12.x or PT2020.3? If the former, you need to upgrade to current version, if the latter, it should work on Catalina.
HTML code is On
Audio tracks stop playing back/outputs disable rtcstudio macOS 395 07-15-2015 07:28 PM
Audio tracks stop playing back/outputs disabled in PT 9.0.6 mingojr macOS 0 08-12-2013 05:25 PM
Recorded audio is not playing back in sync with other tracks ATLracing Getting Started 4 07-08-2013 05:52 PM
Stereo Audio Tracks playing back mono rtebel macOS 2 03-25-2012 09:43 AM
How to record vocal while playing back MIDI? superjunk 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 4 10-22-2006 08:26 PM
