Old 01-16-2018, 12:40 PM
Inglesworth Inglesworth is offline
Default Pitch II audiosuite processing question
I am going through and using audiosuite EQ and pitch shift to modify some elements in my sound design.
My EQ 3 plugin, I have set up to go clip-by-clip and I get the 2 second handles, and it doesn't render my fades. Exactly what I wanted it to do. However, on the pitch shift plugin, the "clip-by-clip" option is grayed out and I can not get it to process with handles and it is rendering the existing fades into the clips as well. Is there a reason the clip-by-clip option is grayed out? Or is there a different way to set it up to process while processing the handles and preserving the fades/edits?
EDIT: System specs would probably help...
OS 10.12.2
PT HD 12.7.1
4.01 GHz Intel i7
64GB RAM
Old 01-16-2018, 01:40 PM
Carl Kolchak Carl Kolchak is offline
Default Re: Pitch II audiosuite processing question
That sounds familiar as an old bug (thought it was fixed).
question about audiosuite dither setting under processing preferences collinsylex Pro Tools 9 4 03-11-2011 12:36 PM
Audiosuite processing Reckah 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 8 08-25-2009 03:20 PM
AudioSuite NOT processing Abomb97 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 2 07-09-2004 02:10 PM
Audiosuite not processing Allen Hallada 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 4 01-06-2002 11:26 AM
AUDIOSUITE NOT PROCESSING el matador 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 2 11-19-2001 06:52 AM
