Old 04-09-2016, 06:29 PM
DJ Hellfire DJ Hellfire is offline
Default Re: -9173 Error caused by UAD Neve 1073 in 12.5
Originally Posted by ArKay99 View Post
Is this happening with your Mac Pro or one of the others, or all three?
Glad I waited before installing 12.5...
staying on 12.4 until all this gets sorted...err bugs fixed.
Only tried on the Mac Pro.
www.HellfireBeats.com
Akai MPC 2000XL, Akai MPC X, Mackie 1202VLZ Pro, Akai Advance 61, Focal Alpha 80, UAD 2 Apollo Quad, UAD 2 Satellite Quad, UAD 2 Octo PCIe, Neve R6 "Lunch Box", Neve Portico 511, Neve Portico 551, Neumann TLM49
Pro Tools 2018.10
Mac Pro 4,1 (5,1 upgrade), Early-2009, 3.46GHz Nehalem 12-Core, 32GB RAM - OS 10.12.6
13" MacBook Pro, Late-2011, 2.4GHz Dual Core i5, 16GB RAM - OS 10.12.6
27" iMac, Late-2012, 3.4GHz i7, 24GB RAM - OS 10.12.6
Old 04-09-2016, 06:30 PM
Originally Posted by YYR123 View Post
The legacy or the new pre with unison?
The new one.
Pro Tools 2018.10
Old 04-10-2016, 12:22 AM
tonepad tonepad is offline
I too am getting -9173 errors on my Win7 clone PT 12.5 install. I'm hardly running any plugs on my current session though I did recently do a Slate VMR update, if I take them out I still get the nag. While I have UAD on this rig I don't have the Neve plugs mentioned here and AFAIR I have only one UAD plug instantiated so far...the Dimension D I believe. I played around with the cache and some Slate Drum settings but it the -9173 will still pop up after awhile. Sooo I booted back to my 12.4 install on my other Win7 drive and the same session is rock solid, the Slate VMR update is not on this install. I will do a roll back tomorrow on the 12.5 clone to 12.4, leave the Slate VMR updated and see what happens. From what I can gather from other users on the forum it seems to be a bonafide bug.
My day job:
Wilson Dyer MPSE
Sound Supervisor: NCIS Los Angeles, CBS Television
Old 04-10-2016, 04:37 AM
Holly73 Holly73 is offline
I think we are talking about different things here. There is several threads about -9173 errors (mainly) in PT 12.5
But the -9173 with UAD 1073 is an instant one. Hit the EQ button and bam...
DJ, can you confirm it is only the stereo version of the 1073 that's affected?
Old 04-10-2016, 05:44 AM
jjnssn jjnssn is offline
Default -9173 Error caused by UAD Neve 1073 in 12.5
On my PC system the instant error that stops playback is a -9171. Indeed I can immediately hit play again and it will not error. I will try to reproduce.
This error had to do with a different plug-in. Removed that plug-in. And system runs fine with the UAD 1073, MP, Vari Mu, and LA-2 on this session. 64 samples.
____________________________________________
W10 Pro / X99 / E5-1650v3 / 64GB ECC / nVidia P1000 / ASUS TB3 AIC
PT HDX1 / OMNI / HD IO 16x16 / 11R / Kontakt Kontrol S49 / Artist Transport and Mix / UAD OCTO Satellite, Apollo Twin MKII &, x8P Thunderbolt
[Late 2013 10.14 MacBook Pro]
Old 04-10-2016, 06:48 AM
TAMBOR TAMBOR is offline
I'm running a similar system to him, but not seeing the problem. I tested with the 1073 and 1081, no issues at all. I'm running W7 SP1, and a 4.4 GHz overclock, however.
Old 04-10-2016, 09:50 AM
john1192 john1192 is online now
can we ask what Plugin it was ???
thank you
OS 10.12.6 for PT 11.3.2 & 12.4 & above
Mac Pro 6-core 3.33ghz (2012) 24gb ram 256gb SSD
Macbook Pro july 2014 2.5ghz 16gb ram 512gb SSD - OS10.12.6 - PT 12.4 & above
lynx AES16e-SRC & Aurora 16
Artist Transport & iPad - Pro |Control - EuCon 3.7 (older Euphonix Branded MC Transport)
Old 04-10-2016, 10:59 AM
Perception by MeterPlugs. I use it as a utility. Normally don't leave in a session. Like I mentioned. Once I acknowledged the error, it worked fine after.
Old 04-10-2016, 12:36 PM
zion's Avatar
zion zion is offline
Originally Posted by DJ Hellfire View Post
Getting the -9173 when using the UAD Neve 1073 preamp/eq. Only tried in one session, but I insert the plugin and as soon as I press the EQ On button, I get a CPU overload error and the -9173. If I leave the EQ off on the plugin, I can use the preamp without an issue. The session pretty much will not play at all with the EQ On. Removing the plugin causes the error to go completely away. Was not happening in 12.4 or lower. Other UAD plugins work fine. The only thing that changed in my system was going from 12.4 to 12.5.
No issues at all here either and I'm on Mac.
Pro Tools 2019.6 | Studio One 4.5 Pro | Pro Tools 12.5.2 HD | Apollo X8 | UAD Octo Sat | UAD Quad Sat | Mac Mini 2018 i7 | 16GB Ram | 512GB SSD | Mojave 10.14.3 | OWC ThunderBay 4 | Drives’s Samsung EVO 860 + 840 + Crucial M4 SSD | Plugins | UAD, Softube, Waves, Nugen, Fabfilter, SSL, Lexicon, Eastwest, NI KOMP 9 ULT, PSP, IKMulti, Antares, Celemony, Slate Dig, etc | AKAI Pro Adv 61 | PreSonus Fader Port | Townsend Labs Sphere L22
Old 04-10-2016, 12:53 PM
Stereo version? My mono one also works fine.
 MBPr 15" (Mid 2015) i7, PT12.4, Studio One 3, UA Apollo Quad Firewire
Neve 1073 - your thoughts YYR123 General Discussion 23 11-16-2014 11:33 PM
vintech 273 vs. Neve 1073 MX582 General Discussion 1 10-13-2006 01:40 PM
Best Neve 1073 jlo1182 Pro Tools TDM Systems (Mac) 24 01-30-2006 04:54 AM
Neve 1073 DIY Kev Tips & Tricks 1 07-19-2002 01:43 AM
Neve 1073 EQ vs. API EQ nwilson@hns.com Tips & Tricks 8 03-14-2002 01:09 AM
