Old 04-01-2013, 04:41 PM
john1192 john1192 is offline
Default Mutetone crashes PT10
hi, Mutetone version 1.0, 1.01, 1.02 all crash pro tools 10.3.4 / Mac OS 10.8.3
anyone else see this .. have to force quit PT here
cheers
john
OS 10.12.6 for PT 11.3.2 & 12.4 & above
Mac Pro 6-core 3.33ghz (2012) 24gb ram 256gb SSD
Macbook Pro july 2014 2.5ghz 16gb ram 512gb SSD - OS10.12.6 - PT 12.4 & above
lynx AES16e-SRC & Aurora 16
Artist Transport & iPad - Pro |Control - EuCon 3.7 (older Euphonix Branded MC Transport)
Old 04-01-2013, 04:43 PM
YYR123's Avatar
YYR123 YYR123 is offline
Default Re: Mutetone crashes PT10
I Just heard about this plug and I wanted to install it but I heard from another poster here on the forum that it was doing that very same thing causing it to hang
Daniel
Old 04-02-2013, 01:45 AM
Holly73 Holly73 is offline
It also crashes PT9 by the way.
 MBPr 15" (Mid 2015) i7, PT12.4, Studio One 3, UA Apollo Quad Firewire
Old 04-02-2013, 06:52 AM
crizdee's Avatar
crizdee crizdee is offline
Had it working fine on PT9 native audio engine.
Tried on HD10 and wouldn't work.
Chris
Producer, Engineer,
Slow Readers Club_Build A Tower top 20 UK album charts
www.ukmastering.com
PT10.3.10 Mountain Lion HD6 accel Magma PE6R4 Control 24 MacPro 12 Core 3.46ghz UAD-2 Octo x2. Manley Vari-Mu, Manley Massive Passive, SSL VHD, ADL600, Grove Tubes ViPre, Tube-Tech CL-1B. Hafler TRM active monitoring.
Old 04-02-2013, 01:46 PM
WombatStudio.Org's Avatar
WombatStudio.Org WombatStudio.Org is offline
Don't know why you'd use muteTone on HD, but ...
The workaround is to disable muteTone first (Option+Command+Click), then remove the plugin.
That mostly worked but I got to the point where I'd just disable it and leave it. Then save everything and try to remove them all after tracking.
Because it wasn't 100% for me I went with not using it all together.
WombatStudio.Org • Digital Recording, Mixing and Mastering in Gibbsboro, NJ • USA
"It's not the gear ... it's the ear"
Old 04-02-2013, 01:47 PM
nstu nstu is offline
cheers
john
When did it crash?
I have it working on 10.3.2 / OS 10.7. but I have to make it inactive before removing it since PT 10. And re-activating works only sometimes. So i have to load it up new as an insert.
Maybe you send a request to Salvator at TritonDigital. When I got that problems with the crash, he told me that little work around.
nMP (3,5 GHZ 6-core, 16GB, 1x 512 PCI-SSD, 2x D700, Akitio Duo Thunder2 with SSD Angle Bird 256 GB & 512 GB) | OS 10.12.2 | ProTools 12.7 | UAD Apollo DUO + Apollo QUAD (both with TB Card) | iPad 3 with PT Control | Euphonix Artist Mix
Old 04-02-2013, 01:53 PM
crizdee's Avatar
Why not? it just goes into mute when the transport is running, which makes it usefull on talkback and communication mics in the live room.
Chris
Producer, Engineer,
www.ukmastering.com
Old 04-02-2013, 02:30 PM
K, cool, you've found other uses for it. muteTone was written for tracking in Pro Tools due to its inability to disable software monitoring when using 3rd party interfaces.
For talkback I use Massey's TB Plugin, has a threshold so it even mutes at idle when the drummer starts banging away as drummers so like to do ...
Crashes using Tritone MuteTone AAX64 MacOSX WarrenG AAX Plug-ins 0 03-02-2014 01:51 AM
(Try this again)-PT10 Crashes At Startup PlasterPirate Pro Tools 10 14 10-30-2013 10:00 AM
PT10 crashes when its idle brenny Pro Tools 10 4 05-24-2013 11:01 PM
Amplitube 3 crashes PT10 cherryred335 Windows 5 10-29-2012 06:21 PM
PT10 crashes alexmoi macOS 5 10-25-2012 07:58 PM
