Old 03-25-2013, 12:28 AM
ASTR ASTR is offline
Default Drum Mic'ing & Adding Compressor?
Hi all
I'm moving to mic acoustic drums with my 003 factory - but i only have 4 pre-amps - any recommendations on cost-effect preamps/mixer for remaining 4 inputs?
I also was given a outboard compressor - but i'm unsure where to add this to the signal chain on the 003. Any advice will be appreciated.
thanks
Old 03-25-2013, 03:35 AM
Default Re: Drum Mic'ing & Adding Compressor?
Cost-effective way to expand your possibilities would be the Focusrite Octopre Dynamic MkII which connects to your system via ADAT and gives you 8 more preamps of decent quality.
The analog compressors connect to your 003 via analog TRS cables. On the PT mixer window, choose hardware insert (i/o) from the insert menu. You need to understand that hardware inserts need to use matching i/o numbers, so if you go out from analog output 8 you need to come back from analog input 8 as well. It's all there in the i/o setup, learning this shouldn't be very hard... good luck!
Old 03-25-2013, 05:10 AM
i was thinking of going with a 4 input mixer with build in pre-amps - super tight budget and all...any obvious mistakes in that thinking - apart from quality loss?
Old 03-25-2013, 05:58 AM
Ben Jenssen's Avatar
Nothing wrong with the thinking.
With a bit of work you can get perfectly good stuff using cheap gear.
Something like this:
http://www.ebay.com/itm/Behringer-12...item4ac2705a71
I wouldn't use the compressor when recording unless it's a fantastic piece of gear. You can't undo it. Much better to use plugins later.
Old 03-25-2013, 09:40 AM
No mistake. You will just end up spending something for the 4 input mixer with cabling, and you would still not have compressors if you feel that you need them. Naturally you would be fine tracking without any outboard processing so you would only need mics cables and preamps.
Anyway, for what it's worth, Focusrite Octopre MkII without compressors costs something like 500 bucks and the Dynamics version gives you a compressor for each channel for something like 200 bucks more. Connects digitally via ADAT so it's all you need for drum kit miking (plus you would still have your original 4 channels available if needed).
Old 03-25-2013, 09:55 AM
Holly73 Holly73 is offline
Another vote for the Focusrite Octopres.
But with a tight budget, before buying a 4-channel mixer, I'd look for something like this (Behringer ADA8000): http://www.ebay.com/itm/Behringer-AD...item257c1c2621
 MBPr 15" (Mid 2015) i7, PT12.4, Studio One 3, UA Apollo Quad Firewire
Old 03-25-2013, 09:56 AM
EGS's Avatar
EGS EGS is offline
Just make sure the mixer has 4 discrete outputs. You might also check your local Craig's List if budget is tight.
Desktop: PT 2019.10 / Win 10 / GIGABYTE GA-X58A-UD3R / i7-980X hex @ 3.9GHz / 32GB / Focusrite LS56
Laptop: PT 10 / Win 7 / HP ProBook 4730s / i7-2630 / 8GB / U-PHORIA UMC1820
Info/Services link
Old 03-25-2013, 10:24 AM
That is just the 8 channel AD conversion. OP would need preamps, because he already has 8 channels of AD
Old 03-25-2013, 10:26 AM
Yep. And you can use whatever outputs are available; for example,
- stereo out for channels 1 and 2 hard panned
- aux send 1 for channel 3
- aux send 2 for channel 4
But still, the Octopre would make life so much easier
Old 03-25-2013, 02:50 PM
Didn't see this anywhere. And also you suggested to buy an Octopre for ADAT connection. The Behringer would offer the same connectivity at a lower price point. Connecting four of the Behringer channels to the Line Ins of the 003 wouldn't work as it doesn't forward the preamp signal to the analog outs.
Overall Drum Mic'ing firsty33 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 0 03-23-2011 08:06 AM
Adding a compressor after recording GtrDude 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 1 04-22-2006 03:11 AM
Some Drum Mic'ing Questions... Equality 7-2521 Pro Tools TDM Systems (Mac) 8 10-03-2005 02:56 AM
Snare drum mic'ing question.... silence_of_stone 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 6 12-03-2003 06:44 AM
Drum Mic'ing Cinemafixer 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 9 01-03-2002 11:49 AM
