Upgraded from Pro Tools 5.1 where you could adjust the gain for the Digi 001 number 3-8 inputs from within Pro Tools, I can't find it in Pro Tools 9.
Obviously the knobs on the 003R do 1-4 but where are the gain controls for inputs 5-8? Unfortunately a search of this forum didn't help and Avid has had my question for a week and has not responded yet (very disappointing). Thanks in advance!
Matt Rushmore ASUS P6X58D-E / i7 950 / 12gb 12800 HyperX DDR3 / GeForce ASUS EN210 Silent 512mb / (2) WD Caviar Blue 500GB SATA 16mb 6.0Gbs / Windows 7 64 Bit / 003R / PT9.0.2 www.reverbnation.com/jmaccadillac |
There are -10 +4 Switches on the Back of the 003 - thats all i believe there is for adjustment.
David - MacPro 6,1 Intel Xeon E5 2.7 GHz 12-Core 128 GB 1066 MHz DDR3 - HDX II Sonnet xMacPro Server - 16x16 HD i/o x 6 - PT 2018.10 - OS X 10.14.4 - ProTools Dock / PT Control |
Correct, these are for hooking up line level devices, which are generally fixed at those two settings.
If you got an external preamp to hook up to those, then you would adjust the gain on that preamp. |
Ouch. Thats really a shame considering Pro Tools 5.1 from 11 years ago had actual gain faders in the software for the analog inputs.
It's a sad day. Thanks for the info! :)
Not sure you are getting it, no version of PT software can make up for the fact that you need a pre amp in front of inputs 5-8 if you are not inputing a -10 or +4 input. Hardware is before software in the audio path. You can always use a mixer or pre amp unit as a front end to give you the needed gain,also a mixer with direct outs will be better as you will have one less opp amp in your path. Hope that helps.
Brent Willoughby Kinetic Recording Studios Orlando FL. USA www.kineticrecordingstudios.com |
There is a trim and a gain plug that may help. Gain is audiosuite only.
Here I am, after time not long... and thankful for the break, What I found when I got there, was that I couldn't stay away! Hobo Shave! |
Did I miss something? 5-8 are line level inputs, you need to have a pre amp, or a source that is already at -10 or +4. There is a switch beside each line input to chose your input signal, but you still need a pre or a source at line level.
![]() Quote:
Just makeing sure I was not going crazy
If you hang around here long enough.......
Gigabyte X79/intel i7 3930K, 32GB RAM, Presonus Studio 1810C https://www.facebook.com/search/top/...0sound%20works I started in this business with nothing..........and I have most of it left ![]() BTW, my name is Dave, but most people call me.........................Dave |
adjust clip gain with dcommand | zakco | ICON & C|24 | 0 | 06-25-2013 06:27 PM |
Can I adjust gain on just one track in? | oldgitguy | Eleven Rack | 3 | 06-24-2013 03:21 PM |
Adjust input gain of Guitar in (ASIO) | ThunderKyss | Eleven Rack | 9 | 04-16-2013 05:16 AM |
How do i adjust gain on 003+ | Maddawg383 | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 25 | 03-09-2009 07:24 AM |
Output gain adjust? | stainless | Pro Tools M-Powered (Mac) | 1 | 04-17-2006 09:43 AM |
