Old 02-14-2021, 12:58 PM
itsjustmeee123 itsjustmeee123 is offline
Default UVI Workstation update weirdness
Does anyone here use UVI Workstation? It says that there's an update in the UVI Portal but when I try and update it after it's downloaded and installing, I get the usual "UVI workstation wants to make changes. Enter your password". Then it just does nothing and goes back to "update" in the UVI Portal after I put in my password. I've updated 2 other UVI libraries without an issue but I've never come across something like this. And it's not a Security and Privacy issue. I've checked. UVI doesn't have a forum so I thought I'd check here.
Update, I figured out a workaround. I just bypassed the UVI Portal and installed it directly.
Old 02-15-2021, 05:13 AM
Default Re: UVI Workstation update weirdness
Having no problem here doing multiple (3) updates through UVI Portal. Falcon, UVI Workstation and PX Memories. All going normal as I write. I'm on a Mac at OSX 10.13.6 - what's your operating system as you give zero system info?
Jack
QAPLA!
Old 02-15-2021, 07:52 AM
ChuckS ChuckS is offline
The UVI Portal has a silent install option in preferences. Maybe that's what you were experiencing.
PT 2024.3 DP 11.31 VEP 7.x with various VIs
NI Komplete Audio 6 on HP Envy 8G i7 Quad Laptop Win11
MOTU 828es ADA8200 MTP-AV on HP Z2 G4 Xeon Workstation Win11
MOTU M4 on MacBook Air M2 2023 Sonoma.4.1
Old 02-15-2021, 08:19 AM
Never used that option - I like to see what's going on. Could be when Portal updated itself it reset options.
Jack
QAPLA!
Old 02-16-2021, 08:18 AM
I actually got around the issue by just searching my hard drive and finding where the download file was and bypassed the portal and installed it manually. It worked fine.
Computer not showing up in Workstation after Windows update m5t Artist Series 0 12-21-2019 01:37 PM
UVI Workstation PB Buffer weirdness Tim R. AAX Plug-ins 0 01-25-2014 08:16 AM
SYNC IO firmware update weirdness emf1138 Pro Tools TDM Systems (Mac) 3 04-29-2004 09:54 PM
6.2.2 Update weirdness on G5 HD3Accel w/Panther FDurrett Pro Tools TDM Systems (Mac) 5 12-04-2003 06:08 AM
MAC, PC or Workstation? Ricky Ricardo 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 5 12-13-2001 05:17 PM
