Old 05-05-2019, 03:43 AM
noxplode noxplode is offline
Default Need help with setting up my TDM system for mixing
I am trying to work on this project:
Around 100+ tracks on 48KHz, no plugins at all, on my rig with these specs:
2x 2.8 Quad Core
34GB ram
OSX 10.9.5
PT HD2 version 8.1.1
Audio Drive is an internal SATA at 7200rpm
and I get messages like this:
https://www.dropbox.com/s/6n4b4j6ut5...%20PM.png?dl=0
My settings are these:
https://www.dropbox.com/s/4u2k83vc98...%20PM.png?dl=0
Is there something I can do to playback all those channels and use RTAS plugins when I will start mixing?
Thank you
Old 05-05-2019, 04:02 AM
Raoul23 Raoul23 is offline
Default Re: Need help with setting up my TDM system for mixing
Change the host processor to 7 for starters
I had this issue with my PC when I ran protools HD and it was down to other things sharing the PCI slot bandwidth? I don’t think you should be getting that issue with a Mac though?
Have you tried another hard drive as it might be on its way out
Raoul Crane
www.blaze-studios.co.uk
PT 10.3.10 HD Accel 6, Mac Pro 5.1 12 Core 3.46hz Dual Boot Lion 10.7.5 and Maverick 10.9.5 32GB Ram Magma PE6R4i Chassis
Old 05-05-2019, 10:11 AM
Just basics: increase the buffer size to the max setting, host processor to 7 as already suggested, and CPU to 99%.
Does this happen to only one session? Or all/many?
What native plugins are you running?
Have you done basic stuff like trashing prefs yet? Still problems—troubleshoot the native plugins you are using. Are their versions compatible with your legacy setup? Remove the rtas plugin files from the plugin folder in batches to see if the problem goes away.
Make sure the system is fully optimized and other crap is not running. Even web browsers can be resource pigs.
Make sure the audio is going only to the dedicated drive you think it is. And no VI samples on that drive.
What exact make/model/spec Audio HDD do you have now?
Try replacing the audio HDD with a SSD, just a low-cost Samsung 860 Evo SATA drive will have much lower latency. The Mac Pro only has SATA II on the motherboard, you can do better there with a SATA III PCIe controller card or a PCIe SSD, but for a basic test the SATA SSD on a motherboard port should be fine.
Old 05-05-2019, 11:01 AM
BScout BScout is offline
You really need to just split your audio files over many drives. A 7200rpm drive isn't going to keep up with 100 audio files. Put 30-40 tracks on every drive and it'll playback fine.
Old 05-05-2019, 11:54 AM
I missed the exact track count, but I suspect that may work OK on a single SSD. Even with just SATA II, since it's seek time not actual bandwith that is the issue. I'd just try one.
Even a low-cost Evo SSD can deliver average IO latencies in the fraction of a millisecond even at high IO queue depths.... while on a good day, rolling down hill, with the wind behind them, clunky old "audio spec" HDD will deliver average IO latencies at ~few to 10ms under load.
Old 05-06-2019, 04:22 AM
My Sata drive is this:
ST2000VX000-1ES164:
Capacity: 2 TB (2,000,398,934,016 bytes)
Model: ST2000VX000-1ES164
Revision: CV27
Serial Number: Z4Z5M5W7
Native Command Queuing: Yes
Queue Depth: 32
Removable Media: No
Detachable Drive: No
BSD Name: disk1
Rotational Rate: 7200
Medium Type: Rotational
Bay Name: Bay 3
Partition Map Type: GPT (GUID Partition Table)
S.M.A.R.T. status: Verified
Volumes:
EFI:
Capacity: 209.7 MB (209,715,200 bytes)
BSD Name: disk1s1
Content: EFI
PROJECTS:
Capacity: 2 TB (2,000,054,960,128 bytes)
Available: 1.31 TB (1,311,752,675,328 bytes)
Writable: Yes
File System: Journaled HFS+
BSD Name: disk1s2
Mount Point: /Volumes/PROJECTS
Content: Apple_HFS
Haven't trashed prefs yet.
Going to try some of your suggestions.
Bought a Samsung EVO to try it out.
Old 05-10-2019, 11:10 AM
digitaltoast digitaltoast is offline
SSD
Old 05-10-2019, 11:15 AM
Originally Posted by digitaltoast View Post
ssd
tla poq wtf ??? I guess you are agreeing a SSD will help?
Old 05-17-2019, 01:02 AM
Inserted a Samsung EVO SSD, moved all sessions there and the system rocks.
I can playback 191 channels at HD2 with 6 DSPs, 7 cores, 99% cpu, flawlessly! Not even one CPU error message.
Thank you all for the help !
Setting up for surround mixing on a small budget bradweeks80 Post - Surround - Video 5 04-20-2012 06:18 PM
PT - New to Mixing ITB - tips for setting up mixes? iamlark Tips & Tricks 9 09-09-2010 10:31 PM
Help with setting up a room for mixing jbaliban 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 1 03-05-2010 06:33 AM
DJ Mixing Best Setting Maybe? DJ Loon Tips & Tricks 1 05-30-2005 07:52 AM
Setting fader levels for maximum mixing headroom Siberian 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 5 10-07-2003 05:43 AM
