Re: focusrite interface with protools
I did that but a window popped up and said "Some paths was made inactive because they could not be assigned to existing path definitions.
Protools 11 Audio Interface: 2i2 Computer: AcerE15 E5-511P-C9BM Windows 8 |
So is the focusrite your main playback interface?
And did you install asio4all?
Yes and yes. Both asio4all and the focusrite interface worked completely fine in flstudio but idk what I'm doing wrong in PT
This should be only the problem of your existing I/o setup....what I had asked you to do earlier. You might have to do it again...because you might have done it for another playback device
Alright I'm going to try that again. I'll let you know what happens.
#16
Ok I did that and nothing happened. I didn't get a input signal from my mic but it kept freezing when I changed my I/O and also it kept freezing what I clicked the record button on the track I had set my I/O at...
#17
Is the machine online? Do you have team viewer? I would be willing to help out, it's up to you.
Another thing is you have a condenser mic you need to have a phantom power enabled. Also most interfaces have a switch to toggle between line in/XLR Might check that, as well as the gain in the input
#18
By machine I am assuming you are talking about my computer in which case is online and what team viewer? I'd be glad to let you assist me in any way. Yes the audio inter face do in fact have a phantom button that I use and the XLR/INST switch is always on XLR because my keyboard is usb. Is teamviewer like a screen recorder?
#19
It will let me login To the computer your using
#20
Alright I'm going to download it. What do I need to do?
New interface - Focusrite | YYR123 | General Discussion | 3 | 02-06-2014 09:10 PM |
Focusrite interface | jayjaystevens | Pro Tools 10 | 2 | 10-02-2013 08:17 AM |
Focusrite 2i4 Interface? | Terry Wetzel | Windows | 6 | 10-02-2013 05:38 AM |
Focusrite introduces Forte interface | nst7 | Pro Tools 10 | 0 | 09-05-2012 08:57 AM |
focusrite interface with protools ? | dubhole | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 3 | 07-22-2009 05:56 AM |
