Optical Format Changes By Itself!!
Anybody else experience this? While working in a session I will start out with SPDIF Mirroring enabled and SPDIF format (not ADAT) selected but somewhere in the course of a session it will switch to ADAT and no SPDIF mirroring by itself which necessitates me having to go into the Playback Engine settings and change everything back to the way it was. Is it just me or what?
Frank S.
Frank Silano FrankenCat Productions Landmine Recording Tampa Bay, Florida http://www.frankencat.com <>< PT 2018.12 (Win) PT 10.3.10 (Win) Mbox Pro Gen 3 Firmware 1.0.4 Focusrite 18i8 Gen 2 (mobile rig) Windows 10 Enterprise (main PT OS) Mac Mojave 10.14.4 (no PT at the moment) |
Re: Optical Format Changes By Itself!!
Its probably a bug, like the one that happens when you group faders for mixing and save the session with all groups disabled, when you reopen that session back up,then groups are enabled and you have to disable them every time for the rest of the days you keep reopening that session. [img]images/icons/shocked.gif[/img]
Gabriel. |
Very strange. Anybody else notice this?
I get it also, drives me nuts! Usually changes when I change from one session to another, even when I keep PT open. I always have to check the box when I first open PT. I use the S/PDIF out to monitor (through my 01v) so when it goes off I notice it right away.
...don't you boys know any nice songs? |
It doesn't really matter to me since I don't use S/PDIF output for anything. But I do play around with these settings. If I want S/PDIF Mirroring disabled I have to disable it every single time that I start PTLE! The setting won't stick! I haven't noticed if the setting gets lost when changing sessions, but it definitely gets lost each time PTLE is shut down.
Mike
-- Mike - HP Spectre x360 Convertible 14t-ea100 - 2.9 GHz (5.0 Max Turbo) i7-1195G7 32GB RAM, OLED 3k x 2k, Iris Xe Onboard Graphics - Windows 11 - PT 2021.12 - PreSonus Quantum 2 - PreSonus Studio 24c - Mackie Onyx 1640i - Samsung T3 and T5 SSDs - Various USB2/3 and Firewire HDDs |
<BLOCKQUOTE><font size="1" face="Verdana, Arial">quote:<HR>Originally posted by English Jim:
I get it also, drives me nuts! Usually changes when I change from one session to another, even when I keep PT open. I always have to check the box when I first open PT. I use the S/PDIF out to monitor (through my 01v) so when it goes off I notice it right away.<HR></BLOCKQUOTE> That's exact;y what I am doing - monitoring via S/PDIF through the 01v. I wonder if Digi Support has any idea about this? Digi - Please chime in if possible. Frank Silano
Although not to deny your claims, I have never witnessed this behavior.
Who is clock master in your setup, Pro Tools or the 01V? Brent |
Easy optical format questions... | bpert | Pro Tools TDM Systems (Mac) | 3 | 02-15-2006 02:04 AM |
Default optical format | MaizeBass | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 2 | 09-03-2002 02:43 AM |
192 : MUST select Optical format for Bay 3 to activate Enclosure Optical inputs????? | el biciclista | Pro Tools TDM Systems (Mac) | 2 | 07-09-2002 10:32 AM |
greyed out optical format pop up--please help | beardeddubster | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 4 | 05-18-2002 05:38 AM |
Which "Optical Format" when using both optical and S/PDIF I/O? | el biciclista | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 1 | 09-23-2001 04:27 PM |
