Old 01-29-2015, 01:01 PM
JLC JLC is offline
Default Asus X99 deluxe/HP Z800 same problem
Hi I have made a new pc based on Asus X99 deluxe.
Everything is woking fine, but with 3 HDx cards I am having a Problem:
PCI 1 Video Card GTX760
PCI 2 Disabled
PCI 3 Disabled
PCI 4 HDX1
PCI 5 HDX 2
PCI 6 HDX 3
I am having exactly the same problem described in the page 16 of the document:
http://akmedia.digidesign.com/suppor...dows_83670.pdf
“Corrupted audio when bus recording (signal inverts every 8 samples) (PTSW-158063)
HP Z800 workstations can drop samples while record
ing when an HDX card is present in PCIe Slot #3 (connected to the Southbridge).
This recording problem is resolved by updating the HP Z800 to the latest BIOS (3.54).”
I understand that is a BIOS problem that can be solbed with a BIOS upgrade, or maybe there is some parameter in the BIOS I should modify.
Could someone at Avid tell me wich parameter or report the error to ASUS so they could make a new BIOS revision with this correction?
Thanks in advance
Old 01-29-2015, 03:06 PM
The Weed's Avatar
The Weed The Weed is offline
Default Re: Asus X99 deluxe/HP Z800 same problem
"This recording problem is resolved by updating the HP Z800 to the latest BIOS (3.54).”
Have you done the BIOS upgrade yet?
Demos: brucehayward dot com
SonoBus
Source-Connect: brucehayward
Options for Remote Direction
Old 01-30-2015, 03:55 PM
dtonthept dtonthept is offline
JLC do you mind if I also ask what components you used for your build? And have you had it running previously or is this your first troubleshoot after the build?
ASUS K8V SE Deluxe & SATA Problem... RCAinTN 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 8 01-11-2007 09:02 AM
Asus K8V SE Deluxe - Need to buy 2 x 1 gig Tracy Lowery 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 3 05-03-2006 06:36 AM
REGARDING THE ASUS K8V SE DELUXE AND RAM glu 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 4 04-19-2005 08:51 PM
ASUS K8V Se Deluxe Problem....AMD 64 3200+ Jake001 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 3 08-08-2004 01:20 PM
Asus K8V Models- K8V- K8V Deluxe - K8V deluxe SE zepp9 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 6 05-04-2004 08:34 AM
