Pro Tools Cannot be opened because of a Problem
Hello everyone, I am new to the forums and also new to Pro Tools. Truth be told I am not an Audio person I am actually a Network Administrator in charge of our Mac lab. I have had a heck of a time getting Pro Tools 9 to run on our Macs and now I can't even get it to start up. We have about 25 Macs that have pro tools on them and we are using the Mbox 3 G as MIDI interfaces. I accidentally installed the drivers for Mbox 2 and now I can't get pro tools to start. That is how I found out we are using the 3 Generation of M boxes. I don't know how to remove the drivers and I cant get Pro Tools to even start. The error message is below. Any help would be greatly appreciated. I think there is something wrong with the Library at least according to the error, but I don't know anything about Pro Tools so I don't know the first place to start.
Process: Pro Tools [364] Path: /Applications/Digidesign/Pro Tools/Pro Tools.app/Contents/MacOS/Pro Tools Identifier: com.digidesign.ProTools Version: ??? (???) Code Type: X86 (Native) Parent Process: launchd [297] Date/Time: 2011-11-01 09:52:43.756 -0500 OS Version: Mac OS X 10.6.7 (10J869) Report Version: 6 Interval Since Last Report: 95808 sec Crashes Since Last Report: 4 Per-App Crashes Since Last Report: 1 Anonymous UUID: BF9D134C-1773-4207-8F09-3D93A4C57041 Exception Type: EXC_BREAKPOINT (SIGTRAP) Exception Codes: 0x0000000000000002, 0x0000000000000000 Crashed Thread: 0 Dyld Error Message: Library not loaded: @executable_path/../Frameworks/CFnd.framework/Versions/A/CFnd Referenced from: /Applications/Digidesign/Pro Tools/Pro Tools.app/Contents/MacOS/Pro Tools Reason: Incompatible library version: Pro Tools requires version 9.0.2 or later, but CFnd provides version 9.0.0 Binary Images: 0x8fe00000 - 0x8fe4162b dyld 132.1 (???) <39AC3185-E633-68AA-7CD6-1230E7F1CEF4> /usr/lib/dyld Model: MacPro5,1, BootROM MP51.007F.B03, 8 processors, Quad-Core Intel Xeon, 2.4 GHz, 12 GB, SMC 1.39f11 Graphics: ATI Radeon HD 5770, ATI Radeon HD 5770, PCIe, 1024 MB Memory Module: global_name AirPort: spairport_wireless_card_type_airport_extreme (0x14E4, 0x8E), Broadcom BCM43xx 1.0 (5.10.131.36.9) Bluetooth: Version 2.4.0f1, 2 service, 12 devices, 1 incoming serial ports Network Service: Ethernet 1, Ethernet, en0 Network Service: Ethernet 2, Ethernet, en1 PCI Card: Apple 2 Port 4Gbps Fibre Channel Card, sppci_fibrechannel, Slot-4 PCI Card: Apple 2 Port 4Gbps Fibre Channel Card, sppci_fibrechannel, Slot-4 PCI Card: ATI Radeon HD 5770, Display, Slot-1 Serial ATA Device: HL-DT-ST DVD-RW GH61N Serial ATA Device: WDC WD1001FALS-41Y6A0, 931.51 GB Fibre Channel Device: SCSI Target Device @ 0 Fibre Channel Device: SCSI Target Device @ 1 USB Device: Mbox, 0x0dba, 0x5000, 0xfd300000 USB Device: Hub, 0x05ac (Apple Inc.), 0x9126, 0xfd100000 USB Device: Keyboard Hub, 0x05ac (Apple Inc.), 0x1006, 0xfd120000 USB Device: Apple Optical USB Mouse, 0x05ac (Apple Inc.), 0x0304, 0xfd123000 USB Device: Apple Keyboard, 0x05ac (Apple Inc.), 0x0220, 0xfd122000 USB Device: Apple LED Cinema Display, 0x05ac (Apple Inc.), 0x9226, 0xfd160000 USB Device: Display Audio, 0x05ac (Apple Inc.), 0x1105, 0xfd140000 USB Device: Display iSight, 0x05ac (Apple Inc.), 0x8508, 0xfd150000 USB Device: iLok, 0x088e, 0x5036, 0x1a200000 USB Device: BRCM2046 Hub, 0x0a5c (Broadcom Corp.), 0x4500, 0x5a100000 USB Device: Bluetooth USB Host Controller, 0x05ac (Apple Inc.), 0x8215, 0x5a110000 FireWire Device: built-in_hub, Up to 800 Mb/sec |
SoftwareUpdater cannot be opened because of a problem | SteveGarman | Pro Tools 10 | 4 | 05-09-2013 05:36 PM |
Pro Tools cannot be opened because of a problem | electriclife | macOS | 5 | 07-07-2012 11:21 AM |
Pro tools cannot be opened because of a problem | Rune Thuelund | macOS | 3 | 10-05-2011 04:18 AM |
PT HD 8.1cs1:Pro Tools cannot be opened because of a problem | MARVINBASS | Pro Tools TDM Systems (Mac) | 2 | 08-25-2010 05:21 PM |
xp rewire 2 problem, reason was opened during pt session | kraaag | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 2 | 05-03-2003 05:53 PM |
