Pro Tools LE error when opened
When i try to open Pro Tools Le, a blue screen shows up and reads: A problem has been defected amd windows has been shut down to prevent damage to your computer. If this is the first time you've seen this stop error screen, restart your computer. If this screen appears again, follow these steps: Check to be sure you have adequate disk space. If a driver is identified in this stop message, disable the driver or check with the manufacturer for driver updates. Try changing video adapters. Check with your hardware vendor for any BIOS updates. Disable BIOS memory options such as caching or shadowing. If you need to use safe mode to remove or disable components restart you computer, press F8 to select Advanced Startup Options, and then select safe mode. Technical Information ***STOP: 0x0000008E (0xc0000005, 0xF71894A2, 0xF6770A20, 0x00000000) ***System32:1zx32.sys - Address F71894A2 base at F7187000, DateStamp 45e99595 Culd sumone plz help to get rid of screen and allow program 2 wrk
Re: Pro Tools LE error when opened
Update your PACE drivers from www.paceap.com
install error, can't be opened because it is from an unidentified developer | IVcrane | macOS | 1 | 12-03-2013 10:11 PM |
Pro Tools cannot be opened because of a problem | electriclife | macOS | 5 | 07-07-2012 11:21 AM |
First Time opened pro tools 10 error?! | applecore3401 | macOS | 4 | 10-23-2011 09:31 AM |
The document could not be opened because it was created with an older version error | tritonkorg | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 5 | 08-04-2011 12:59 PM |
Error: The MIDI Server can't be opened. | The Drummer | Pro Tools TDM Systems (Mac) | 10 | 02-26-2011 02:01 AM |
