Asus X99 deluxe/HP Z800 same problem
Hi I have made a new pc based on Asus X99 deluxe.
Everything is woking fine, but with 3 HDx cards I am having a Problem: PCI 1 Video Card GTX760 PCI 2 Disabled PCI 3 Disabled PCI 4 HDX1 PCI 5 HDX 2 PCI 6 HDX 3 I am having exactly the same problem described in the page 16 of the document: http://akmedia.digidesign.com/suppor...dows_83670.pdf “Corrupted audio when bus recording (signal inverts every 8 samples) (PTSW-158063) HP Z800 workstations can drop samples while record ing when an HDX card is present in PCIe Slot #3 (connected to the Southbridge). This recording problem is resolved by updating the HP Z800 to the latest BIOS (3.54).” I understand that is a BIOS problem that can be solbed with a BIOS upgrade, or maybe there is some parameter in the BIOS I should modify. Could someone at Avid tell me wich parameter or report the error to ASUS so they could make a new BIOS revision with this correction? Thanks in advance |
Re: Asus X99 deluxe/HP Z800 same problem
"This recording problem is resolved by updating the HP Z800 to the latest BIOS (3.54).”
Have you done the BIOS upgrade yet?
JLC do you mind if I also ask what components you used for your build? And have you had it running previously or is this your first troubleshoot after the build?
ASUS K8V SE Deluxe & SATA Problem... | RCAinTN | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 8 | 01-11-2007 09:02 AM |
Asus K8V SE Deluxe - Need to buy 2 x 1 gig | Tracy Lowery | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 3 | 05-03-2006 06:36 AM |
REGARDING THE ASUS K8V SE DELUXE AND RAM | glu | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 4 | 04-19-2005 08:51 PM |
ASUS K8V Se Deluxe Problem....AMD 64 3200+ | Jake001 | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 3 | 08-08-2004 01:20 PM |
Asus K8V Models- K8V- K8V Deluxe - K8V deluxe SE | zepp9 | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 6 | 05-04-2004 08:34 AM |
