Dual Monitors (Video)
Anyone using dual video monitors with protools? Does protools support it? Can you place the mix window on 1 monitor and the edit window on another?
Re: Dual Monitors (Video)
Yep , not a problem !
I have been using duals since I have had PT and while PT itslef will allow you to stretch the windows and seperate the edit and mix screens, it will not save these settings. You must do it manually each time. However to our rescue comes a fellow by the name of SwapHappy. He has created a utility to do this for us called WindowPlacer. Just search the DUC for those names and you should find what you need.
--joe |
Can anyone give me directions on setting this up?
Rail
OK I must be doing something wrong but Ive looked in the FAQ link above 2 times now and have not seen a link for windowplacer
Item 23b. Q: Does PTLE support Dual Video Monitors?
Rail
Why should I register a Username? Why do you ask for two email addresses? Do I have to accept cookies? How do I login? Help! I'm having trouble logging in What is the string that appears beneath my username in posts? What are these Titles about? I forgot my password! How do I change my password? How do I add an image to my message? Is there a limit to signature image size? Can I attach a file to my post? What are the rules? How do I edit my profile? How do I edit my display preferences? Why is a post's subject so important? How do I find posts that may already have the answer to the question I have? What does the flashing envelope icon on the Menu bar denote? What do the letters in the Received Private Messages display denote? I'm having problems getting the URL tags to work How do I layout my posts so as to have white space between paragraphs? Is there a spellchecker? What if I make a mistake in my post? What if I post in the wrong forum? Can I use html in my posts? How do I put a poll in my post? I want to see more (or less) posts per page. What's with all the buttons? Why are Subject, Poster and Posted on clickable? Can I run my own forum? |
The 3rd post in the Windows LE Forum is sticky and labelled FAQ... not the BBS FAQ.
Rail
How many here using Dual Video Monitors ??? | Swaphappy | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 366 | 04-27-2004 05:25 AM |
Dual video Monitors | MediaMaster | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 5 | 04-06-2004 12:20 PM |
Want DUAL VIDEO MONITORS, here is a cheap way... | Swaphappy | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 23 | 02-13-2004 11:47 AM |
dual video monitors | tamara | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 4 | 04-28-2003 11:12 PM |
DUAL VIDEO MONITORS | mancave | General Discussion | 4 | 08-05-2001 09:00 PM |
