Old 02-24-2021, 02:18 PM
AlessioB AlessioB is offline
Default Most efficient way to export takes
Hi everyone,
I'm wondering what the most efficient way to export takes for clients is. Right now, say in a classical recording, I have to select a take, click bounce to disk, wait for it to render and to it all over again for each take. I've seen that Cubase has introduced a render queue feature and I was wondering whether Pro Tools has a way to export takes in an efficient way. Maybe export all playlists as a stereo file each or something like that.
Does anyone know?
Thank you very much!
Cheers and have a great day
Old 03-07-2021, 01:39 PM
Default Re: Most efficient way to export takes
If you show playlists, then you can click-drag across(from the end, all the way back to zero) and consolidate so that each playlist is a single audio file. With them all selected(highlighted),open the CLIPS bin on the right side and choose Export Clips as Files. I would create a folder on the desktop to send the files to. Then copy that folder to an external drive to pass on to the next person that needs to work on them.
Old 03-10-2021, 05:37 PM
Led Led is offline
You can just trim the take to length, add top or tail fade if needed, consolidate the clip, give it a name you will recognise and make sure you are renaming the disk file as well in the option, then it will be sitting in the audio files folder of the session ready to go.
Old 03-11-2021, 12:38 AM
Ben Jenssen's Avatar
I think you missed the point; Exporting files(multiple), not one by one. Albee got it, consolidate files from zero, across tracks, they'll show up as selected in clips bin, and you export selected from the clip bin menu. All at once. And if you had sensible track names when they were recorded, they will be recognizable when exported as files.
Old 03-11-2021, 12:48 AM
Sardi Sardi is offline
Also, there’s no real need to export the clip if it’s been consolidated. Unless you plan on changing the sample rate, file format, bit depth etc.
Once consolidated, they’ll be in your Audio Files folder. Sort by newest and there’s all your files you just consolidated. Exporting is just going to double the disk space and take more time. Just grab the consolidated files from the Audio Files folder and upload or copy them to wherever they need to go.
Old 03-11-2021, 12:50 AM
Sardi is of course right.
Thanks.
Best workflow to export all playlist tracks/takes? Ed Boogie Pro Tools 12 1 06-01-2016 12:09 PM
7.4 more DSP efficient than 8? gaas Pro Tools TDM Systems (Mac) 10 12-28-2010 02:25 PM
Digital Performer takes export as OMF? Bryan Cook 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 0 10-25-2010 04:23 PM
Missing takes mystery from tracking session! but unused takes remain? crizdee Pro Tools TDM Systems (Mac) 4 11-24-2009 09:27 AM
Efficient means of auditioning multiple takes/playlists? spiritG Pro Tools TDM Systems (Mac) 2 11-18-2008 11:34 AM
