Strange window behavior
MacPro4,1 Nehalem upgraded to 5,1.
2x 6 core 3.33 GHz, 24 GB RAM. GT120 stock video, 2 displays. 850 EVO 500 GB, 2 partitions. Money partition is PT 12.4 Vanilla, OS X 10.8.5. New partition is PT 12.7.0 Vanilla, macOS Sierra 10.12.3. On the 10.8.5 (Money) partition, plug in windows behave normally. Put 'em on any display over Edit or Mix windows, they appear normal. On the 10.12.3 (New) partition, opening a plug in either window on either display is normal. See "EQ3 Main Window". Moving the same plug in to the opposite window and display results in a white replacement of the header controls. See "EQ3 Second Window". It doesn't matter which display is the "opening" one, the "moved" one shows the white header. 100% reproducible. This happens with Avid plugs (EQ3, Fairchild 670), Izotope (Ozone 5, Ozone 7 Advanced, Insight), Plug In Alliance (bx_meter). I have downloaded, but not installed 12.7.1. I do not have Sierra 10.12.2 available. I seem to recall a similar thread from several months ago, but I can't find it, so here I am clogging the internet for a solution.
Bob Without a song The day would never end |
Re: Strange window behavior
Hi, My first guess would be a video driver issue. Have you checked to see if there's an update available? (Make sure you have a backup ready in case it causes problems!)
Help Us Help You ______________________________________ Chris Pro Tools 2024.3 Focusrite LS56 Focusrite Pro40 (3) Slate Digital VRS8 Analogue Tonebuss 24 Channel UAD-2 OCTO Core Accelerator UAD Volt 2 macOS 10.15.7 32 GB DDR4 RAM 4.01GHz Quad-Core Intel Core I7 NVIDIA GeForce GT 740 2 GB |
Further troubleshooting... Deleted Prefs... No difference Installed 12.7.1... No difference Further observation... Once moved to the opposing display, the borders and controls go white as before. Closing the plugin from the Insert display in either Edit or Mix window and reopening heals the window and leaves the plug window in the last place it was dropped. Kind of a workaround.
Re: Strange window behavior (workaround works!)
Strange behavior | CrimeLab Audio | Tips & Tricks | 8 | 04-22-2013 07:34 PM |
8.0.1 Strange behavior?!?!?!?!?! | danander11 | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 25 | 09-03-2009 03:44 PM |
FB strange behavior | Branko | Post - Surround - Video | 2 | 11-26-2006 04:35 PM |
Strange Pop Up Window and Behavior with QT / 6.9.1 | AVGuru1 | Post - Surround - Video | 2 | 02-07-2006 05:53 PM |
strange file behavior - task window madness | smlworld | Pro Tools TDM Systems (Mac) | 0 | 09-24-2003 08:48 AM |
