Old 10-24-2016, 11:39 AM
caseyholford caseyholford is offline
Default THANK YOU for multiple audiosuite instance!
Just thought I would halfheartedly try holding down "shift" while opening a new Audiosuite plugin ... had not yet tried it in 12.6. And LO! It works! So amazing!!!! Thank you to the Pro Tools team for adding this long lamented feature. Saves me so much time that I could afford to log in and write this note about how awesome it is! Grazie mille!!!!!
----------Casey Holford------------
songwriting | studio | recent work
Old 10-24-2016, 12:31 PM
Sardi Sardi is offline
Default Re: THANK YOU for multiple audiosuite instance!
This feature was added a few years back in v10.
Old 04-03-2019, 05:43 AM
saspro saspro is offline
"To open multiple AudioSuite plug-ins simultaneously simply hold down [Shift] while selecting a new plug-in from the AudioSuite menu."
This does not work for me. It just replaces the currently open plug in window, like it always used to.
Anyone know why?
PT HD 12.8.3, MacPro 10.12
Old 04-03-2019, 08:41 AM
jeffro's Avatar
jeffro jeffro is offline
Originally Posted by saspro View Post
...This does not work for me. It just replaces the currently open plug in window, like it always used to...
Check out Target Button info for AudioSuite plug-ins in the ref guide.
linkedin
The Weed's Avatar
The Weed The Weed is offline
Hold down Shift before you open the AS menu.
Demos: brucehayward dot com
SonoBus
Source-Connect: brucehayward
Options for Remote Direction
Old 04-04-2019, 05:09 AM
A-ha! So for me its:
Turn off the target button in first AS plug, then
Hold down shift, then
Pull down and 2nd AS plug.
Thanks, peepz!
Old 04-04-2019, 06:48 AM
crizdee's Avatar
crizdee crizdee is offline
about 7 years
Chris
Producer, Engineer,
www.ukmastering.com
Old 04-04-2019, 12:36 PM
gives's Avatar
gives gives is online now
Yes.. A great tool here for us!
G
Composer/Sound Designer/Protools 2024.3 Ultimate, MTRXII-TB3, DADMAN MOM, Cisco SG350-10MP EthernetHUB, KLANG:quelle 4 Channel Dante™Headphone Amp, DVS,MADI, Mac Studio Ultra,128 RAM/4TB SSD, Ventura 13.6.6, DP 11.3.1, Logic Pro X 10.8.1 DOLBY ATMOS Facility/MPSE Motion Picture Sound Editors Avid Certified Professional ProTools/Dolby ATMOS
No track freeze? Nor process with multiple Audiosuite plugs at once in PT9?? mixaudio 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 2 11-10-2010 07:54 AM
Track Freeze and/or processing with multiple Audiosuite at once coming soon? mixaudio 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 3 04-19-2010 08:24 PM
Multiple Audiosuite Windows Simultaneously Stephen Webster Post - Surround - Video 11 03-14-2008 07:05 AM
Multiple AudioSuite Plug-ins on the Desktop at One Time? Brian in Charlotte Tips & Tricks 6 07-05-2007 11:16 AM
Multiple Audiosuite Windows open Suncoast Pro Tools TDM Systems (Mac) 2 05-30-2001 08:43 AM
