Old 05-06-2008, 08:57 PM
Martin Vipond Martin Vipond is offline
Default Moved to Mac from windows - some plug ins are missing?
I moved from my aging Athlon XP box to my MacBook Pro 17"
Here are the details on the new install
MBP 17" 2.4 Ghz Core2 Duo 4GB RAM
OS X 10.4.11
Digi002
Factory Bundle
Install went easily enough.
Set the OS according to Digi's recommendations.
Transferred my most recent sessions to an external FW drive.
Tested the setup with the demo session. Works great!
Installed all of the Factory Bundle stuff.
mounted the Pace Anti Lock key.
Opened a recent session. No TLSpace. About 1/2 of the Moog Plugs are missing. No SampleTank.
Verified that the plug ins exist in /Macintosh HD/Library/Application Support/Digidesign/Plug-Ins. Yep they're in there. But the icons for the missing plugs are different. Other than that, everything looks pretty normal to me.
I'm stumped. But I use TL Space a lot and both the Bomb Factory compressors, the BF-3A is missing.
Here's what's missing from PT sessions:
bomfactory BF-3A
Cosmonaut Voice (I actually use this in a session)
JOEMEEK Compressor
JOEMEEK Mequalizer
Moogerfooger Delay
Moogerfooger Ringmod
SampleTank2 SE
SansAmp PSA-1
TelRay Delay
TLSpace Native
Voce Chorus Vibrato
Voce Spin
That looks like most of the Factory Bundle to me.
So what did I miss in transferring my plug ins?
Thanks for any help you can muster!
Martin Vipond
Two Legs Productions
Creativity comes from MOTION
So don’t sit Still!
Old 05-07-2008, 05:10 AM
Phil Ogden Phil Ogden is online now
Default Re: Moved to Mac from windows - some plug ins are missing?
Most likely the plug-ins are not intel compatible. If you select a plug-in and press Apple 'I', what is displayed in the 'kind of field' (Power PC or Universal)? You need the latter.
Also PT7 onwards introduced a different plug-in format. Plug-ins should have a .dpm extension.
http://www.myspace.com/philogg
Old 05-07-2008, 05:38 AM
Yep. That's the trouble. I never gave that a thought...
So it's off to the Downloads section to see if Digi has some updates.
Thanks Phil
mjv
Martin Vipond
So don’t sit Still!
Plug ins Missing (Kontakt, POD Farm) from Pro Tools 10 Plug-in list smythmakesmusic macOS 28 05-13-2017 05:41 AM
ilok missing (windows 7) soulcrusher31 Windows 5 04-14-2013 04:21 PM
Plug-in folder moved colourednoise Windows 4 04-01-2013 06:47 PM
Waves plug ins missing after hard moved to new computer Roland 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 3 07-01-2009 10:28 AM
Can't install 7.4 - "Missing a Windows XP Update" DUCHUNTER Pro Tools M-Powered (Win) 2 04-21-2008 10:13 AM
