Warm vocals on Mbox 3
Hi Guys,
Maybe somebody can assist me out there in Avid-land... I've been trying to get to grips with an Mbox 3. Having recently switched over from Cakewalk to Pro Tools, I thought I'd also do the standard switch with pre-amps etc... I have been working for years using an SE2200 mic through a Behringer UltragainPro tube pre amp, and had found a lovely sounding warmth on this set-up. (and considering the low price of the Behringer, have always been amazed by it) Having moved over to an Mbox (because it had always been given good reports from the people I know using it), I'm a little disappointed with the sound I'm getting... it's not bad, but I can't say it's an improvement in any way... in fact, it isn't an improvement pppffffff. Can anybody out there give some advice about getting more from the Mbox... I'm looking for a gentle rounded warmth for vocals... any set-up suggestions are very welcome... Thanks |
Re: Warm vocals on Mbox 3
Maybe the tube of the Behringer is giving you what you really want, so why not try using that, and patching it into a Line/DI input of the Mbox? In any case, the results depend on every part of the equation, from the voice, the sound of the room, the mic, the preamp, the processing you choose(plugins) and even on the listening system(monitors combined with the room). That's a lot of possible contributors to the final sound. Personally, I really like an FET mic thru a tube pre(and despite what manufacturers want us to believe, to get tube sound, really does take a tube circuit. While I am sure there may be some exceptions to this rule, they are few and expensive
I didn't realise I could patch the Behringer with the Mbox... that's something I can certainly try... for some reason or another I've always been under the impression that patching one preamp to another results in a deterioration of sound quality... (I don't know if I read that somewhere, or was I told by somebody) What would you suggest about levels on the Mbox for this set-up?
Thanks |
Go in with a TRS connection and turn the Mbox GAIN knob all the way down. While its true that technically you are not bypassing the Mbox pre, you are skipping a gain stage and you should still retain most or all of the character of the tube preamp. The Pro version of the new Mboxes has a pair of dedicated line inputs.
What was the interface you were using with Cakewalk? But that said, there really isn't THAT much difference is just about any interface within the same price range group, especially the under $500 one. There may be slight sound differences in choices made by the designers and manufacturer, because there won't be a colorless, transparent input in that range, and bumps in certain frequencies are made to perk up the listener and hide the fact that it's not an audiophile signal path. Sometimes they go for a more present sound at supposedly neutral settings, and sometimes a warmer sound, and any low cost widget with tube in the name is definitely aiming to serve it up on the warmer side, for better or worse : ) Your Behringer is a different animal than the mBox pre's for sure, and I agree with albee1952 that you should use it, if you like it, as part of your rig. Just jam it in a line in you'll have it.
Thanks guys.. will do....
How to 'warm up' an oud? | David Topple | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 2 | 07-27-2010 02:54 PM |
Delay in Vocals on mbox | Ishaq | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 3 | 08-26-2004 05:07 AM |
mbox vocals | ggmmss | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 1 | 08-14-2004 12:01 AM |
I want a Church for my vocals, a big warm one, please... | Rammelt | Tips & Tricks | 9 | 08-13-2003 11:45 AM |
wide, warm, and in your face vocals??? | kir2k2 | Tips & Tricks | 8 | 12-19-2001 07:13 AM |
