Old 09-25-2009, 09:13 PM
xq3js xq3js is offline
Default Strike - Content not found
I've just upgraded to PT8.
I get that message "Content not found, please run the SetContentLocation application" when I load Strike.
Tried running the Set Content Location app several times, tried re-installing Strike, but none of them seem to work.
Any suggestion before I have to re-install the whole system from scratch?
Is this a compatibility issue with 8.0.1?
Any information is appreciated, thanks.
Old 09-25-2009, 09:19 PM
flommer flommer is offline
Default Re: Strike - Content not found
Type exactly this into the forum search field:
strike "content not found"
See if any of the resulting threads have an answer to your problem
MacPro3ghz, 6GB, 10.7.5, PT10.3.2, Digi002 factory/toolkit2/PTIEP, 11R
Old 09-25-2009, 10:20 PM
danander11 danander11 is offline
Here I am,
after time not long...
and thankful for the break,
What I found when I got there,
was that I couldn't stay away!
Hobo Shave!
Old 09-26-2009, 06:45 AM
Thanks guys
I am reading thru the search results, hope I can find something that works
Old 09-26-2009, 09:15 AM
Not much help in the search results so far
Thanks anyways
I'll figure out a way some how
Old 09-27-2009, 05:08 PM
thopman thopman is offline
I had this problem about a month ago. Make sure your Mac (I assume you are on Mac?) system disk is NOT formatted as "case sensitive".
You can check this on the "Get Info" for your Hard Disk.
This style of Mac formatting does NOT work with Strike!
Hope this helps. I know how maddening it can be. It took me over a month to figure it out!
--Terry
Old 09-27-2009, 07:20 PM
Does this dialog appear when Strike Content is installed to default location?
filosofem
Old 09-27-2009, 07:37 PM
As Filo said.. also, make sure that the setcontentlocation.exe file is in the same directory as the *.big files of Strike. (on a PC that would be C:/Program Files/Digidesign/Strike/ by default).
If you have installed or moved the *.big files to somewhere else, youwll have to copy the setcontentlocation.exe file to there, and then run it.
If that doesn't work.. well, I'm out of ideas.. Good luck though!
Here I am,
Hobo Shave!
Old 09-27-2009, 08:16 PM
jeffro's Avatar
jeffro jeffro is offline
Post Re: Strike - Content not found
Please check out KB 287471 and let us know if this doesn't help.
linkedin
Old 09-27-2009, 10:15 PM
Originally Posted by thopman View Post
--Terry
Thanks thopman,
I've read all your posts and I know how frustrating it was for you.
I just checked my disks, both OS and audio, and they were formatted not as case sensitive.
So there must be something else that I'm missing..
STRIKE content not found [solved] john1192 Virtual Instruments 34 11-04-2015 12:16 AM
Strike Content Not Found after Running SetContent Location darbyclash34 Virtual Instruments 40 06-11-2013 07:59 PM
Strike - Content not found Vincent Joly The Drum Room 5 10-02-2011 06:21 PM
Velvet & Strike: Content Not Found error thopman Virtual Instruments 13 07-20-2009 06:14 PM
Strike Content File not found atomicaudio Virtual Instruments 1 07-01-2007 06:55 AM
