CPU usage problems...help!!!
Hopefully someone can help me!!!
I am running an Mbox on PT5.3.3 on P4 using XP with 512 memory. I am quite a beginner with Pro Tools so please bear with me. I am experiencing CPU problems: after a lengthy recording session, every time I open Pro Tools the CPU usage shoots straight up to 100% (using windows taskmanager). This obviously means I cannot use playback let alone record anything. This was a sudden problem, one minute it was fine and then this... The CPU usage marker in Pro Tools is perfectly normal, about 20%. Please can somebody help???? thank you in advance... Gaz
I can see much clearer now I'm blind... |
Re: CPU usage problems...help!!!
It is normal (in 5.3.3) for the Windows Task Manager CPU Usage to show 100%; almost all of it used by PTLE.
Ignore it, the meter in PTLE tells you what you need to know. With 6.1 and up, Windows reports more accurately.
Quad 2.5 G5, 4.5G RAM |
Ok, thanks for your time. I'll give it another go.
I thought it was strange for the CPU indicator in Pro Tools to differ so drastically to the Windows Task Manager version! Thank you again. Gaz
Pro Tools HDX useless?!?!?! major RAM usage problems 32bit | dustin_m | Pro Tools HDX & HD Native Systems (Mac) | 33 | 11-11-2019 10:49 AM |
Problems with CPU usage | jemanike | Windows | 6 | 04-14-2012 10:10 AM |
CPU usage problems | michaiel | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 0 | 03-08-2010 11:24 AM |
M-Powered 7.3.1cs7 and Plug in CPU usage problems | RichrdC | Pro Tools M-Powered (Win) | 2 | 02-09-2009 04:11 PM |
system usage problems with HD upres | jerbear | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 7 | 11-01-2007 02:19 AM |
