Old 11-14-2018, 12:23 PM
katerkarlo katerkarlo is offline
Default Low Latency Monitoring different in PT 2018.10 and HD Native?
As I use Pro Tools with an RME audio interface, I am very happy Avid has finally introduced a way to turn off software monitoring.
Does this feature work the same way in HD Native? I think the manual creates some confusion ...
On p.514 there's a chapter "Low Latency Monitoring" which describes that if you select Options > Low Latency Monitoring then software monitoring for incoming audio signals on record-enabled tracks is automatically disabled.
But then it goes on: "To use Low Latency Monitoring assign each track to the selected Low Latency Monitoring Path as set in the I/O Setup Output page (see “Low Latency Monitoring” on page 60). Only tracks assigned to these outputs use Low Latency Monitoring."
That refers to HD Native only, doesn't it? Because in my PT there is no such option in the I/O Setup page.
So basically there's two kinds of "Low Latency Monitoring" options, one of which exists only in HD Native. That's kind of confusing.
Anyway, what I want to know is: Does the option "Low Latency Monitoring" in the options menu exist in HD Native too and will it disable software monitoring too? I am asking because I might be working on an HD Native system with my RME interface.
PT 2018.10 Windows 10 x64. RME Fireface 802.
Old 11-17-2018, 01:23 PM
Default Re: Low Latency Monitoring different in PT 2018.10 and HD Native?
Nobody? Maybe I should rephrase my question: How does LLM work on HD Native systems and in PT Ultimate + third party interface?
The manual says that LLM disables software monitoring so that you can easily monitor through the mixer of your audio interface. In an HD Native system this doesn't make sense to me, since Avid interfaces don't have built-in mixers.
It would make sense though if you were using PT Ultimate with a third party interface.
And why do you need to define a LLM output path if software monitoring is disabled?
Old 11-17-2018, 02:08 PM
Carl Lie Carl Lie is offline
Not sure I can help as I've been on HDx for a while but I'm confused where you say you'll use HD Native with the Fireface as the interface which is throwing me off.
My understanding is that if you use the Fireface then you not utilizing HD Native at all. Are you saying you'll be working with someone who has HD Native and you'll want to use Ultimate with your interface when not using HD Native?
C
PT 2021.10 HDX 16x24 -Mac Pro 12 Cores 48 GB RAM OS 10.13.6 - API 16 channel - AMS Neve 16 channel, AMS-Neve-SSL -Pres/Processing, Bock Audio, BLUE Bottle, Neumann, Josephson -Mics, Bogner, Kemper- Guitar, Chandler Zener-Curve Bender Outboard/Master. UAudio, Waves, Plugin Alliance etc.
Old 11-17-2018, 02:27 PM
For me, running HDN card, HD and 192 IO on Windows 10, LLM has rarely worked as expected(and in some versions of PT, its been outright broken). Also, I was under the impression that LLM only worked with Avid hardware(if that's not correct, I'm happy to be wrong)
Having said that, I have never had any issues tracking at a 64 buffer setting. Is your system not powerful enough?
Old 11-17-2018, 02:36 PM
That very much sucks.
C
Old 11-17-2018, 06:05 PM
thomasd thomasd is offline
Hi, in Protools 2018.10 there is a preference in the Mixing tab to "Allow sends to persist in LLM". That's the solution for me, so LLM is on, I monitor for example the bass that is overdubbing directly through the preamp to a headphone mixer, and I send the playback tracks out on the send to e.g. output 3-4 of my sound card, which also is patched to the headphone mixer, Behringer 16 channel, that way I can keep my buffer at 512, which means I can already have a lot op plugins in my mix, so it sound like it should, while still overdubbing parts.
Cheers,
Thomas
Old 11-17-2018, 06:47 PM
/* snip */
As Carl already kind of said, the questions here make no sense.
The low latency monitoring utilizing the HD Native low latency hardware mixer only applies to DigiLink interfaces.
Avid has tried to clean up some confusion by naming the old HD software Pro Tools Ultimate. So let’s try to use that naming here as well.
LLM with Pro Tools Ultimate used with FireWire or USB or other non-DigiLink interface behaves the same as Pro Tools (standard).
Old 11-18-2018, 04:30 AM
Thanks, that's basically what I wanted to know. I mistakenly referred to such a setup as HD Native in my initial post.
Old 11-18-2018, 04:38 AM
That's precisely what's causing confusion here. LLM was introduced with HD Native (when you couldn't use HD software with third party interfaces). And apparently it still works the same in a HD Native system.
But with the latest versions, LLM has become available too in standard PT. That is, it's called the same but actually it's something different which is basically the option to turn off software monitoring so you can monitor your audio inputs through an external mixer.
IMO, the user manual contributes to the confusion, because the instructions on how to use LLM in standard PT (p.514) are simply wrong (see my initial post).
Old 11-18-2018, 05:25 AM
ChuckS ChuckS is online now
LLM has been available in standard PT third party interfaces for quite a while, but it was only available for the first two inputs. The new LLM update extends it to all inputs of the audio device.
PT 2024.3 DP 11.31 VEP 7.x with various VIs
NI Komplete Audio 6 on HP Envy 8G i7 Quad Laptop Win11
MOTU 828es ADA8200 MTP-AV on HP Z2 G4 Xeon Workstation Win11
MOTU M4 on MacBook Air M2 2023 Sonoma.4.1
Pro Tools 2018.1 low latency monitoring issues stakeoutstudios Pro Tools 2018 61 04-15-2020 07:15 AM
Still can't get Low Latency Monitoring With My HD Native Omni! mmk Pro Tools HDX & HD Native Systems (Mac) 8 04-10-2020 01:19 PM
Low Latency Monitoring with HD Native David Sandwisch Pro Tools HDX & HD Native Systems (Mac) 31 03-31-2020 01:57 PM
PT 2018 - Low Latency Monitoring issue: mutes signal briaboy Pro Tools 2018 5 06-25-2018 04:23 AM
HD Native low latency monitoring CamM Pro Tools HDX & HD Native Systems (Mac) 34 11-06-2010 03:11 AM
