Sync/TC Instability When Recording From VTR
Okay, here's a weird one that I'm hoping the more experienced of you can shed some light on...
Recorded about 2 minutes of audio via AES audio into Pro Tools (HD 7.3, Sync I/O, digital only 192) from an SRW-5500 tape. Everything sync'd, time code matched, happy indicator lights everywhere. Made a few edits in the captured region, inserted it back into the same tape. Next day, client wants another change near the previous one so I ingested the same section as the day before with an additional few minutes at the head and tails so I'd have the audio for the latest change. This is in the same Pro Tools session I'd used previously, same deck, same tape, and under the same conditions. But I saw immediately that the region I just recorded was somewhere between one quarter and one half frame later than what I had recorded the previous day. I then ran some tests using a scratch tape. In PT, I created about a 2 minute long region with 1 frame long audio pops every second and layed it back to the tape. Disconnected the deck from PT & used a remote controller to play and jog the tape to verify my pops were recorded in the right spots. It all looked good. Then I re-recorded the same section back into the same PT session. The new region was 2072 samples late. I re-recorded to new tracks in PT four more times while trying different sync settings in PT. Every time, the recorded region was later than the original one. The tightest I could get it was 470 samples late. Pretty small, but enough to bother me. And the fact that I got different values for each pass is especially disturbing to me (even two subsequent passes with the same settings were 400 samples different). The way things are sync'd in this facility seems a bit odd to me: Sync is distributed through some kind of generator/router (an Evertz something I thnk) and when laying back to an SRW deck, PT is locked to an SD reference while the deck is locked to an HD ref. Both reference signals are generated by the Evertz and, I'm told, are phase aligned. The Sync I/O seems happy but... Am I expecting too much from what I'm trying to do? I was expecting "near" sample accuracy but maybe 470 samples IS near and I'm just being fussy. Anyone have any ideas on this?
Yesterday, I cudn't evun spell injunear. Now I are one! Last edited by Tom Smith; 12-19-2008 at 01:57 PM. Reason: spelling |
Re: Sync/TC Instability When Recording From VTR
MmmHmm, yeah, no, that doesn't sound right. What frame rate? Are you using machine control or chasing code. LTC or serial TC?
Yes, using machine control, 23.976FPS, serial time code, typical normal stuff...
Yesterday, I cudn't evun spell injunear. Now I are one! |
Ah, while this all appears to be typical normal stuff, there are key pieces of information here that lead me to believe your problem lies in the way you are working. The first is that you are using a SYNC I/O, and not a SYNC|HD. The primary difference is that the SYNC I/O cannot lock to tri-level sync. This, in turn, makes it impossible to use 23.976 serial timecode reliably, as the timecode address of each 23.976 frame has no relationship to each sync pulse at 29.97. This relationship of timecode addresses corresponding to frame edges is required for serial timecode to work properly. Try all of your tests while using LTC from the VTR as your positional reference. I think you will then get the results you expect.
and the HDCAM-SR decks suck.
I've just about got the shop I'm working at to upgrade to a Sync HD, but I think that'll take a couple of months to push through with the money people. In the mean time, do you think it would better to run my PT sessions at 29.97? The deck can be clocked from an SD ref, translate TC and has a format converter built in (which I use all the time anyway since the tapes are 4:4:4 and my pix monitor will only do 4:2:2)...
Yesterday, I cudn't evun spell injunear. Now I are one! Last edited by Tom Smith; 12-22-2008 at 03:32 PM. Reason: spelling |
Well, this problem continues. We're trying to work out what's going on...
I've done the test using LTC from the deck & still experience the audio being shifted later when recording back into Pro Tools. Differences between successive passes are relatively small, 1 quarter to 1 half frame later. Does anyone know, given what I'm trying to do, how much accuracy I can expect? My understanding, which may be mistaken, is that I should be able to get "near sample" accuracy doing this. But does anyone know how near is near? I was assuming just a very few samples: 10, 12, etc. not 400 - 2000. Can anyone tell me what a reasonable expectation would be?
This is an issue when running Serial Time code without locking tri-level sync. I have run tests with the SRW-5500 recording back sync pops and the variation is +- .75 frame.
Randall |
SSD 4 and instability | nozzles | macOS | 2 | 01-23-2012 07:28 AM |
Instability of 7.3 | midi sordino | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 0 | 09-13-2007 05:35 AM |
General instability in PT7, looking for help. | deafguy | Pro Tools TDM Systems (Mac) | 12 | 04-30-2006 11:02 AM |
Bluetooth and Instability? | Mount Royal | Pro Tools TDM Systems (Mac) | 1 | 09-09-2005 05:14 AM |
System Instability With DR-008 | Amerihudge | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 5 | 05-27-2003 11:15 AM |
