Template copies on 6.9.1 - make it stop!
I just upgraded from 6.7 to 6.9.1 on 10.3.8 G5
I use a template to start sessions off by copying it from the desktop to a new folder on the recording HD. They are set to stationary pad. This used to work like this in 6.7 - open template session and it would give me the option of edit statioary or new session. On 6.9.1 no go - it justs copies the template straight away and starts a new session with that name. I lose my careful disk allocation as well.. Any ideas? |
Re: Template copies on 6.9.1 - make it stop!
Read the “Read Me” file installed by the installer (notice how those clever and professional “Item Namers” have named things?).
Andre Knecht We’ll fix it in the shrink-wrap. (Frank Zappa) . |
Hi.
Here's what I do... Launch Pro Tools and Save a New Session where you want to. Go to Windows > Show Workspace Find your template and drag it into Pro Tools. -or- Try File > Import Session Data Cheers! Link. |
I can't locate a readme file relating to protools
"Item Namers"??? As I said this didn't happen on 6.7 down.. |
www.digidesign.com/support/docs/
AAAAAAAAAAAAAH!!!!
I just upgraded to 6.9.1 OS 10.3.8. My workflow is RUINED!!!!!! I don't want work arounds!!! Is this a PT issue or an OS issue?? Does anyone know how to get to the former Create New Session or Edit Existing???? ANYONE??????? |
It's an OS X issue.
Use Import Session Data and import from your template session -- it's fast and painless. Rail
Platinum Samples www.platinumsamples.com Engineered Drums for BFD •••••••••••••••••••••••••••• |
Or....instead of double-clicking on your template, open your template session from the file menu in Pro Tools. You will get the familiar "Create new or Edit Existing" dialog you are used to.
That wasn't so hard, was it? rcm
Save early and often! (or once a day whether you need to or not...) |
Eric Seaberg • San Diego, CA A.E.S., I.E.E.E., S.M.P.T.E., S.P.A.R.S. |
Templates always make automatically copies : How ? | andre tchmil | Pro Tools TDM Systems (Mac) | 6 | 12-14-2006 11:45 AM |
Template copies itself?! | Sunzate | Pro Tools TDM Systems (Mac) | 3 | 08-25-2005 01:48 PM |
does 'save session copy in' make perfect copies? | michaux | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 4 | 02-05-2004 10:58 AM |
does 'save session copy in' make perfect copies??? | michaux | Pro Tools TDM Systems (Mac) | 1 | 02-05-2004 05:17 AM |
how to make a template that will make LE 5.3 stay put over two monitors?? | lavoll | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 1 | 03-10-2003 03:43 AM |
