Old 03-18-2005, 01:48 AM
djkiller djkiller is offline
Default Tweaking xp for protools
some of my rtas plugins lag by 1 second when using vocals and my playback engine every now and then says i need to boost the cpu ussage or get rid of some rtas plugins. the cpu usage is already at 85% and my buffer is set at level 2 or 0 most of the time. i'm just trying to tweak my computer for the best performance possible. i only have 512ram and i have a 2.4ghz pc running on xp pro. i am getting more ram soon but so far i just run into a little problem here and there. my questions is, does anyone know or know a good site that has info on disabling windows xp services specifically for protools and the overall system setup for protools?
also i have a 160bg hard drive and a spare 60gb hardrive. i'm running protools, ableton and reason ect. on the 160gb and the 60gb has old songs i'm cleaning up. would it be better to dump my tracks straight to the 60gb during recording and after i'm done mixing just put the final mix back on the 160gb?
Old 03-18-2005, 10:46 AM
Sharritan Sharritan is offline
Default Re: Tweaking xp for protools
WINXP Tweak Site
Try this.
Old 03-31-2005, 09:10 PM
gonzo99 gonzo99 is offline
You should always have your audio on a separate drive from your system/ProTools drive. You will get better performance because the disk doesn't have to try and read audio as well as read OS/ProTools files. Therefore audio is read more quickly.
gonzo
gonzo
HANSON'S RAZOR:
Never attribute to evil that which can be adequately explained by stupidity.
Tweaking Bigpit 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 5 04-19-2008 12:51 PM
Tweaking your Ram stevedresser83 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 3 02-09-2008 01:43 PM
Tweaking Windows XP and Protools TULL 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 28 05-01-2004 02:04 PM
xp tweaking pauleddy2 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 1 08-03-2002 08:49 AM
KR7A need help tweaking Valeri 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 1 06-06-2002 07:16 AM
