Old 06-17-2020, 08:34 PM
davision davision is offline
Default Is PT compatible with Catalina 10.15.5?
I've just installed 10.15.5 on my mac and my PT (installed a new version 2018.12) won't start. With no Time Machine restore option available, I'm assuming I am screwed?
Old 06-17-2020, 08:55 PM
JFreak's Avatar
JFreak JFreak is online now
Default Re: Is PT compatible with Catalina 10.15.5?
PT 2020.5 working fine here on 10.15.5 although not supported
Janne
Old 06-17-2020, 09:10 PM
Hi Janne - that could be a clue - so did you have to install all the 2020.5 drivers etc. for it to work or that was the version you had already?
Old 06-17-2020, 09:11 PM
JFreak's Avatar
I made a clean install of 10.15.4 and ran 2020.3 with it first, then updated to 10.15.5 and 2020.5 without issues
Janne
JFreak's Avatar
Compatibility info here. Just noticed you are using 2018 version which is not going to work with Catalina
Janne
Old 06-17-2020, 09:42 PM
Thanks - I’ll install the 2020.5 version, see how I go - this is potentially my turning to Logic Pro and abandoning PT moment
Old 06-18-2020, 12:38 AM
Thanks for that clue Janne - I’ve updated driver from PT 2018.12 to 2020.5 and that works with Catalina 10.15.5
Old 06-18-2020, 12:39 AM
JFreak's Avatar
No problem
Janne
Old 12-17-2020, 12:44 PM
PRSWILL PRSWILL is offline
I am experimenting with running PT 10 on a new mac running 10.15 and I am getting an error saying it won't run as it needs 10.7 or newer- obviously I have that. Any clues? I am NOT upgrading my PT to a new version.
Old 12-17-2020, 12:55 PM
JFreak's Avatar
PT10 needs 10.8 and might work on 10.9 but no chance with 10.10 and later
Janne
Using ffworks to create Catalina Compatible Video EarHole Post - Surround - Video 0 05-21-2020 10:09 AM
mac os catalina 10.15.3 pedjababic Pro Tools 2020 14 04-19-2020 01:32 PM
Which Versions of Pro Tools are Compatible with Catalina MfMcAdam macOS 2 03-26-2020 07:18 PM
Mac Catalina compatible version? [email protected] Pro Tools | Intro Discussion 2 03-22-2020 10:48 AM
Hammond B-3X 1.1 update available (& Catalina compatible) Peter - IK Multimedia Partner Announcements 0 10-30-2019 02:05 PM
