Old 05-29-2020, 02:12 AM
richists richists is offline
Default I/O setup not the same in edit and mix windows
Hello everyone, I have a problem that seems very easy to solve but I'm just getting mad because nothing works.
I bought an Apollo Twin Duo and set up my I/O settings as usual. I used the UA-standard. Then I wanted to send a signal through Line 3/4 outputs to my outboard compressor. But I can't adjust the Line 3/4 output in Pro Tools. First the outputs still keep their old names, second the output 3 and 4 are greyed out, when I chose them. What am I'm doing wrong? It always worked when I set up the I/O setup but now it doesn't. Has it maybe something to do with the Apollo settings? Tried there everything too but it just doesn't work. Thanks in advance for any help!
I attached two screenshots, so that you see what I mean.
Old 05-29-2020, 03:54 AM
Emi's Avatar
Emi Emi is offline
Default Re: I/O setup not the same in edit and mix windows
Go to busses menu in I/O and hit default.
Mac Mini M1 | Mac OS 12.6.1 Monterey | Avid Carbon + 2x Carbon Pre | Pro Tools Studio 2024.3
Old 05-29-2020, 05:11 AM
Actually that was the first thing I did.
Old 05-29-2020, 05:30 AM
Hello everyone. I really don't know what happened but after a restart with the parameter RAM reset shortcut it works. Seems it was the computer and not Pro Tools. Sorry for bothering.
How to setup seperate Mix and Edit windows on Dual Monitors G.roots 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 3 11-03-2007 08:11 PM
Edit midi setup in 002??!~ Help!~ bluesguy 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 0 11-22-2005 06:50 AM
Edit Midi Setup?? bluesguy 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 2 11-21-2005 11:19 AM
"Edit MIDI Setup" Setup Menu Item is Missing! altemir 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 0 09-08-2004 12:24 PM
a less expensive adr edit setup fred Zager General Discussion 0 03-20-2004 05:12 PM
