Go Back   Avid Pro Audio Community > General Discussion & Off Topic > General Discussion
Old 04-29-2020, 12:37 PM
ramonetl ramonetl is offline
Default Has anyone upgraded their mac pro 2013 cpu?
Im thinking of doing that this year, going from 6 core to 12. I already upgraded ssd and ram when I got it but am debating doing the cpu. The OWC video makes it look straight forward but what I dont know is will I need to flatten and rebuild the system or whether it will just pickup the cpus and run with it? Any input on that is appreciated.
Old 04-29-2020, 12:47 PM
Southsidemusic's Avatar
Default Re: Has anyone upgraded their mac pro 2013 cpu?
Hey
Ask Jfreak (Janne) who is a Moderator as he did upgrade his trashcan to 12 core and had a good result IHO so wait and he will comment..
He doesn’t have a life right now so LOL
Best Regards
Christopher
#thestruggleisreal
South Side Music Group
WEBHOME
Old 05-13-2020, 10:25 AM
UltimateUser1 UltimateUser1 is offline
It’s easy.
Old 06-04-2020, 11:27 AM
I am more curious if I would need to reinstall. Ideally if I could just swap it out and then boot up without doing anything that would be ideal. Reinstalling would be extremely involved and while I could time machine it or use some backup, its not an ideal process.
Old 06-04-2020, 02:55 PM
EGS's Avatar
EGS EGS is offline
Originally Posted by ramonetl View Post
... what I dont know is will I need to flatten and rebuild the system or whether it will just pickup the cpus and run with it?...
I did a CPU upgrade on a Windows build. It worked great & was a decent performance boost for cheap. In my case I had to flash the bios, but that was not too painful.
I am not a Mac expert, but it should work for a Mac Pro. I'd listen carefully to the Mac gurus right here, plus OWC, Google, YouTube, etc. Get the exact CPU upgrade that is compatible with your exact MAC Pro model (i.e. motherboard). Good luck!
Click for audio/video demo
Click for resume
Old 06-04-2020, 03:38 PM
BabaAtmos's Avatar
BabaAtmos BabaAtmos is offline
No...never thought about it...
Old 06-04-2020, 03:44 PM
JFreak's Avatar
JFreak JFreak is offline
Originally Posted by Southsidemusic View Post
Hey
Thanks a bunch
Yea trashcan CPU upgrade is possible if you know what you are doing. Do not even consider doing it unless you have applied thermal paste between processor and heat sink some time before. If you do it wrong, you will melt your processor after the upgrade.
Basically trashcan CPU upgrade means tearing the whole thing apart and rebuilding it from million pieces. But it only takes couple of hours. So many different types of screws involved you better have some system to organise them as you go. Remember, breaking things is easier than putting it back together.
And for the record, my trashcan is 10-core 3.0GHz which Apple never sold. It has slightly better single-core performance and slightly worse multi-core performance than 12-core 2.7GHz.
Janne
Old 06-04-2020, 03:45 PM
JFreak's Avatar
No need to reinstall software, you are only swapping CPU
Janne
2010 Mac Pro vs 2013 Mac Pro Touchwood Studios Pro Tools 11 45 12-10-2014 06:21 PM
2013 Mac Pro and PT HD 11 georgepeter macOS 3 03-24-2014 09:24 PM
The New 2013 Mac Pro blackc7 Pro Tools HDX & HD Native Systems (Mac) 2 06-19-2013 08:54 AM
Chat Transcript | Avid PT 11 Webinar at NAB 2013 | 04/09/2013 Meads Pro Tools 11 13 04-29-2013 10:29 AM
