Old 02-22-2020, 08:58 AM
joren joren is offline
Default Move clip to stereo track - panning is wrong - FEATURE REQUEST
Hi
I think this has been a pain in the ass for a very long time:
Often when you move 2 mono clips to a stereo track, the panning of the left channel remains in centre, while the right channel moves to right, as you'd want it to be.
When you go the other way (stereo to 2 mono tracks) the panning changes to both centred with is what you'd expect. I often do this in film post to edit one of the channels.
But when you move them back to a stereo track, panning is messed up, mostly on the left channel only. This is very annoying and causes mistakes and loss of time.
It also happens when you drag in a stereo file from finder/workspace and put it accidentally on two mono tracks. You'd want to be able to move it to a stereo track without the panning being messed up.
It could be very useful if there was a setting in prefs that would default to the panning you'd mostly expect. Centre for mono channels, L/R for stereo channels.
Mac Pro 8 core OSX Mojave
PT10HD, PT11HD, PT12HD Native
3x Avid Artist Mix, Euphonix MC Transport, PT|Control
Old 02-22-2020, 11:30 AM
capt kirk capt kirk is offline
Default Re: Move clip to stereo track - panning is wrong - FEATURE REQUEST
sort of on topic, but the ability to go back and forth between dual mono and stereo is great. I use it all the time to switch panning on a stereo sound, or to adjust out of whack balance/eq for all kinds of stuff
www.kfaudio.ca
Old 02-22-2020, 12:09 PM
Yeah indeed but then you would want the behaviour to be consistent right?
Alwas keep the stereo panning or always go to centre,
not one channel centred and the other panned!
Or is this behaviour caused by something else that I am missing or doing wrong?
Old 02-22-2020, 12:11 PM
reflexson reflexson is offline
Turn off copy automation with clips and that won’t happen.
Paul Cox
www.226recordings.com
Old 02-22-2020, 02:57 PM
Thanks for your reply, yes but then you have to remember to put that back on...
Which again may lead to even bigger mistakes.
Why should it pan one channel centered and the other correctly? It seems inconsistent even with 'automation follows edit' enabled it still treats the left and right channel differently.
Just looking for best possible efficiency...
Old 02-24-2020, 06:26 AM
simonchase simonchase is offline
Avid have known about this for years.
They don't give a crap about these minor bugs
PT Ultimate 2023.9.0 - MacOS 13.4 - MacBook Pro (Late 2019) - 2.4 GHz 8-Core Intel Core i9 - 64 GB 2667 MHz DDR4 - Apogee Quartet - Avid Link 2022.12
Old 02-24-2020, 07:13 AM
daeron80 daeron80 is offline
8 years they've let this slide?
David J. Finnamore
New feature request, or am I doing something wrong? Kryst 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 3 09-07-2009 05:26 PM
Writing audio to the wrong drive: feature request Kenny F Pro Tools TDM Systems (Mac) 2 05-30-2007 05:59 AM
Panning Feature Request (if not already possible...) Vank Pro Tools TDM Systems (Mac) 3 04-20-2007 02:44 AM
Feature Request - Temp split stereo track fader... JSR Pro Tools TDM Systems (Mac) 1 05-10-2006 01:30 PM
feature request: Importing split stereo files... uno1234 Pro Tools TDM Systems (Mac) 2 06-02-2000 08:47 AM
