Old 03-03-2020, 04:11 PM
anguswoodhead's Avatar
anguswoodhead anguswoodhead is offline
Default HDX Ultimate - 2019.10 7 2019.12 - video export issues
I've been using Pro tools to import a video, master the audio, then bounce to video
I understand it uses Quicktime to do this
I upgraded to Mojave - got a metal video card etc..
I've upgraded to 2019.12 - had video export issues
then rolled back to 2019.10 - same issues
the video bounce has issues
When I used 2018.12 on high Sierra it worked perfectly.....
I'm guessing it's just Quicktime settings
any help much appreciated
thanks in advance.....
https://www.glasshousestudios.com.au
Mac Studio M1 Max
32 GB ram
macOS Ventura 13.1
24 core Metal 3 GPU
Avid MTRX Studio
Pro Tools Ultimate 2023.12
HDX card
AVID TB3 1 slot PCie Chassis
Old 03-04-2020, 10:50 AM
reichman's Avatar
reichman reichman is offline
Default Re: HDX Ultimate - 2019.10 7 2019.12 - video export issues
It should work the same on High Sierra and Mojave. Are all the videos you're testing with using the same video codec? If you are able to, try converting to ProRes on Mojave and bounce to that.
Nathaniel Reichman
Producer/Re-recording Mixer - New York
Nathaniel Reichman | IMDB | LinkedIn
Old 03-09-2020, 02:33 AM
So I stayed on Mojave
But went back to 2018.12
All working fine now
I'm hoping when PT2020 lands this bug will be sorted
Thanks for your help.
Mac Studio M1 Max
32 GB ram
macOS Ventura 13.1
24 core Metal 3 GPU
Avid MTRX Studio
HDX card
HTML code is On
Pro Tools 2019.12 Ultimate Crashes 2019 Mac Pro rmccam Pro Tools 2019 11 02-28-2020 03:59 AM
2019.10 ULTIMATE possible VOLUME bug Cryos Pro Tools 2019 2 11-17-2019 05:42 AM
2019.5 Ultimate on a Mac Pro 5,1 DenverAudioGuy Pro Tools 2019 44 05-28-2019 03:25 AM
D-Command & PT Ultimate 2019.5 rmccam ICON & C|24 5 05-09-2019 12:49 PM
