Old 07-23-2007, 05:41 PM
110 ohm 110 ohm is offline
Default Using second DVI port on graphics card for Picture Playback
I was considering using the second DVI port of the graphics card on our New Mac Pros connected to the HDMI input of the projector as an alternative to Mojo and Canopus. I plan to us DV25 codec quicktimes.
Anyone tried this. How is the sync with this setup?
Thanks,
Jon
Old 07-23-2007, 05:46 PM
Craig F Craig F is offline
Default Re: Using second DVI port on graphics card for Picture Playback
should work well
Thank you,
Craig
Old 07-24-2007, 01:51 PM
The golfer The golfer is offline
I dont know about the mac pro. But I tried it a few time with my G5 and it worked well. The downside is the picture in dvi and HDMI is best seen at native resolution. This means you have to switch your monitor preference to your movie resolution for each project or movie to optimize the quality. You can also use this application QT Sync to change your movie
size to the resolution of your projector. The reason I am still using a canopus is because the dvi output, vga output and canopus(projector) give me 3 monitors instead of two. the DVI output has much less latency than the canopus but with both scenarios you would have to check your sync with syncheck
Serge Hamel
Mixer / Sound Designer
http://www.netpostproduction.com
http://immersivesoundvr.com/
Old 07-24-2007, 02:00 PM
Just a little correction. Monitors have only one native resolution. So your movie would look GREAT in dvi and hdmi at that resolution only. But it would still look good at other resolutions...
Serge Hamel
HTML code is On
Do I need dedicated graphics card to run Pro Tools with hd picture? RobertPaulson Pro Tools 9 4 09-12-2011 09:05 AM
8400 GS graphics card and mbox dont like each other:-/ getting distorted playback buyghostbeats 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 1 03-21-2011 09:01 AM
size of picture pushed thru DVI port Fritz Post - Surround - Video 2 01-18-2006 10:11 AM
graphics port adapters (OT) E-an Pro Tools TDM Systems (Mac) 2 07-18-2001 01:50 AM
Quicktime picture to firewire port Gonzo Pro Tools TDM Systems (Mac) 0 08-22-2000 03:31 PM
