Old 09-24-2015, 06:20 PM
jgbsound jgbsound is offline
Default Super Short selections disable play (spacebar) function?
I will be moving around quickly in my project, and sometimes, I'll click where I need to go in the timeline, but will accidentally move the mouse slightly, thereby making selection a tiny selection. (Probably a 10/100th of a second.
I hit the spacebar and it plays this tiny clip, but then the spacebar locks out.
It doesn't crash the program. But I have to hit RETURN to go back to the beginning of the project and use a previously setup memory location to get back to where I was working.
Weird thing is that everything else seems to be working just fine. I just can't use the spacebar to hit play again until I return to the beginning.
Has anyone else had this happen? If so, have you found a fix? My workaround is fine, but it's super annoying to have it happen because I have to jump back and forth to solve it.
Thanks for any help you can give me!
i7 3930k, Asus P9X79 Pro Mobo, 32gigs gskill ram
Windows 8.1,
ProTools 12HD
S3 Console, Artist Transport
Focusrite Saffire Pro 56
John
Old 09-24-2015, 07:23 PM
Default Re: Super Short selections disable play (spacebar) function?
That's never happened on my rig(and yes, I make that same goof a lot)
Old 09-26-2015, 12:01 PM
AlexLakis AlexLakis is offline
Same here...Could this be an Artist Transport or a S3 thing?
Old 09-26-2015, 02:51 PM
You should not have to go to the beginning, just click outside your selection and you should be fine. Never had that issue nor heard of it.
pro-tools-pc.com
TRASHER Pro Tools Utility(updated 4-11-2024)
Intel I7 9900k
Win 10
Old 09-26-2015, 11:12 PM
Stig Eliassen's Avatar
John, what if you hit 1 on the numpad to step back to clear the selection?
Old 09-27-2015, 12:05 AM
Ray JB Ray JB is online now
Up or down arrows will clear a selection and navigate to either end of it
Old 09-27-2015, 01:19 AM
Jeez, I must be getting old. Forgot about those two (too).
Thanks, Ray.
PT 8 delay when hitting spacebar to play irthwirm 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 2 01-21-2009 07:56 PM
spacebar no-play bug...solution? guy.fi 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 0 12-16-2007 09:50 AM
keyboard short cut for group enable/disable southboundloco Pro Tools M-Powered (Win) 1 02-01-2007 06:12 PM
ProTools doesn't always play with the spacebar... Bixby 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 144 12-07-2006 03:42 AM
freezes: startup/spacebar play dwilson Pro Tools TDM Systems (Mac) 1 03-23-2000 10:08 AM
