Old 10-31-2003, 09:48 AM
JFreak's Avatar
JFreak JFreak is offline
Default drum miking
hi there.
what kind of miking setups you generally try first? what kind of setup you would think were best if money wouldn't come in the way?
i usually start with overheads (rode nt5) one meter away from kit. i first put them 1,5 meters high, in the centerline a little over 90 degrees away from each other. and distance between rodes some 20cm. if that doesn't work right away, i try regular XY miking (bring them close to each other and turn 90 degrees inwards). when i'm satisfied with the kit's sound from overheads, i move on.
second thing is the kick. i have noticed i use beyerdynamics opus65 all the time. i've tried audix d4, shure b52, akg d112 but opus wins all the time. d4 is good though, and i've not yet had chance to try the new d6, but as time being i use the opus. i place a little pillow inside kick, let it touch the beater head gently, and then place the opus inside off-axis and almost touching the pillow.
then i do the snare. i place a sm57 to bottom side almost touching the snare wires, about 45 degrees angle. and of course another sm57 top side just inside snare rim, almost zero degrees (!) angle. i reverse bottom mic phase, naturally.
at this point i have the drummer warm up and tweak eq:s a little. if i'm satisfied with the sound, i dont even bother miking toms. it all depends on the drummer's touch - if he's gentle with cymbals, i can lower overheads to get more toms. if he's a smasher, i need to keep overheads high and therefore mike the toms.
if needed, i use audix d2:s for toms. i place them in almost 90 degrees angle a little inside rims (so i'm not pointing to the center). and i don't drive tom mics at hot levels.
so...
how do you guys do drum kit?
if i had the money, i probably would try neumann 184:s as overheads. beta57:s are in my experience not as good as sm57, so i wouldn't use them even if i got them free. (of course you can buy me a pair of those, i can use them elsewhere). as for tom mics, i'd have to buy dozens of different mics to experiment. i rarely use them and have no real preference. tom mics are in my opinion the least important factor in kit sound.
Janne
Old 10-31-2003, 10:04 AM
brinaddison brinaddison is offline
Default Re: drum miking
I must agree with you on the Beta57, it's noisy and bright/no tone. The Audix D6 is in my opinion the coolest kick mic out there at the moment. It just always sounds killer. D4 is for snare/toms i think. For overheads 184 will give you a nice velvety sound without making the cymbals sound to large or brash but it will still let the toms through nicely. I set them up about 2 and a half stick lengths above the snare, good Phase distance. For toms the D2 or SM57 dynamic mics work realy nice but you could also try Micro-D by Audix. A little different sounding depending on tast. I feel micro condensers sound good sometimes and othertimes sound like S*@#. depends on the drum really.
Last but not least a good drummer who hits hard is the best mic you can have on the kit.
www.hypeschwartz.com
Digi001
(RME adi-8 pro)
G4 MMD Dual 1g + 1.25g RAM
PTLE 6.4 (DVToolkit)
Mac. OS 10.3.3
3 Lacie 80g FW Audio Drives
Old 10-31-2003, 10:28 AM
antiphase antiphase is offline
I would recommend using the D6 on some toms..........and use a E602 for the kick. Its got the same attack as the D6 but more low beef. Try that D6 on a tom and you might be amazed.
www.soundgeekproductions.com
drum miking ideas for >this< kit? eric22rr The Drum Room 15 07-01-2011 11:39 PM
Drum Miking uestion automatic8 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 8 09-02-2009 02:40 AM
Kick drum miking xterraguy 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 22 03-12-2009 05:40 AM
Drum Miking with 002 and PTLE eminentbliss 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 3 11-15-2004 02:15 PM
Drum Overhead Miking? Erik Braund Tips & Tricks 18 12-13-2001 06:35 AM
