Hello,
It may be an IRQ resource conflict. Check the following: -Open the Control Panels>System>Device Manager tab and go through each device list and disable all third party drivers and disable all ports not being used (network card, SoundBlaster, modem, third party mouse, USB controllers, SCSI card, etc). Once the computer reboots, check your resources. You can get a list of which resources are currently being used from the Control Panel>System>Device Manager window. Highlight the Computer icon and click “Properties.” If the Digi001 is sharing with a Com port or anther device (like a network card), move the card to another PCI slot to force Windows to assign it a new number. Mike |
The system display this error in blue screen: "Map Buffer Globally failed"
digi 001 PT LE 5.01 Wave driver 1,7 windows 98 SE mobo Dfi model ad77 pro Atlon XP2100+ Memory: 1G PC 2100 DDR in two modules (512 per unit) Video: Ati Radeon 7500 (with last drivers downloaded) System and audio drives 40G 7200 rpm Note: I cant'n update to PT LE 5.3 requiered PT LE 5.1 serial number (my version is 5.01 and this serial is not acepted for the dowload form) |
![]() Quote:
Good luck, Allen [img]images/icons/wink.gif[/img] |
Thank you mike, my problem begin after install aditional memory module, with 512MB PT works perfect, but with 1024MB apears this error. Note: I probe diferent types and brands of DDR modules.
some people reported problems when using over 512 MB memory with the digi001. I suggest you bring your memory back to 512 MB.
What's that? - That's the machine that goes "pling". Bastiaan |
Dalwdm error | Holy Shaker | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 4 | 02-28-2004 01:05 PM |
TELL DIGIDESIGN - DALWDM ERROR | OHENEBA | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 4 | 06-29-2003 08:14 AM |
DALWDM Error:please tell DIGI... | tjkili | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 1 | 07-20-2002 08:52 AM |
Dalwdm Error ??? | Dany | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 6 | 01-26-2002 10:04 AM |
DALWDM Error...Digi plz help | tjkili | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 3 | 07-26-2001 11:43 PM |
