Moving playlist to a different channel
Hi there, I do a lot of vocals recording in loop mode. After recording, is there a way to move all the playlists to a different channel (usually routed to a bus with some compression and eq ) ? So far I have been able to move just the last take while all the other playlists remain on the recording channel.
Thanks in advance for your help. |
Re: Moving playlist to a different channel
Maybe :
Recording Track , Track View : Playlist Audio Track with Compressor/Eq , Track View : Playlist Recording Track : Shift-select all Playlists and Ctrl+Alt-drag all the Playlists to the other Track If there are not enough Playlists in Track View on the AudioTrack for processing, I would create more by doing a bogus Loop Recording on that Track. For all of the above : Preferences , automatically create new Playlist when Loop Recording
PT 11.3.2 HD , RME Fireface 800 , Genelec 5.1 , Win7 64bit Professional , i7 3930 Hexcore , 48GB Ram , SSD System + SSD PT Session/Audio + SSD Video (all Samsung 840 Evo) + Spinner 1TB Data , 2x Radeon HD 5450 \\ SD 633 Femto MKH8060 MKH8070 MKH30/MKH40 DPA4060 |
Thanks Joachim, that does actually work. However the fact that I have to create new playlists in the channel with eq is a workflow killer when I have many vocals takes to comp, which is always the case.
Thanks again, Oscar |
Hi PT Lover, yes that's what I have been doing, duplicate the recording track with all the playlists and then changing the output to the Bus I want the vocals to go to. Then I go back to the recording channel and I delete all the takes from there.
I can't think of any faster way. Cheers, Oscar |
I think, with duplicating the recording track, you then have to alt-drag the plugins and sends of the processing track to the duplicated track, and maybe assign a different output.
I would make a session template, where I loop-record a 2 second selection 10 times on the processing track. Now there are 10 playlists in view. Takes 20 seconds. Then delete those bogus-recordings. Save the whole session set-up as a template. Edit : and with Ctrl-dragging from the recording track, you do not need to delete the clips on the recording track, just a transfer
..uhm..damn, you are clever..
Yep, just tried quickly. That should do it for me. Thanks a lot! |
..and actually not..I tried to create a template, I made several bogus recordings and deleted the files. The empty playlists stay in view but if I switch to waveform view they disappear once I switch back to playlists view.
I think I'm making it too complicated in trying to replicate the workflow I have in Logic..I'll have to adapt to a new way. |
I was wrong about deleting the bogus recording. Those little fake bogus recording audio files in the session template do not hurt, I think. They get "dragged over" from the recording files. Thanks for the response, I should never stop testing and experimenting .
Thank you for your help.
Moving audio region without moving automation? | tokolosh | Post - Surround - Video | 6 | 04-09-2014 06:11 AM |
Moving a mixer channel | mikeyman | Pro Tools 10 | 3 | 02-12-2014 12:54 AM |
A way to create a new playlist when re-recording over playlist section? | jschmidtiii | macOS | 2 | 08-13-2013 02:28 AM |
Moving an AUX channel | morrison.ece05 | VENUE Live Sound Systems | 3 | 07-07-2011 10:32 PM |
CRC errors & Moving output channel strip | Jae Hwan Kim | VENUE Live Sound Systems | 4 | 08-08-2006 08:44 AM |
