Old 02-26-2015, 11:34 AM
BondAudio BondAudio is offline
Default Re: What is AAE error -35 ?
Convert the H264 to ProRes or DnxHD.
Mac Studio Max
Pro Tools Ultimate
PT | Control
Focusrite Clarett+2
JBL LSR-305
Auratone SSC 5C
Soundminer v5 Pro
Old 03-11-2015, 07:47 AM
sammyfarr sammyfarr is offline
Originally Posted by corym View Post
I just found that, if I had a network drive with the same name mounted, pro tools would generate aae 35 error. Once I dismounted that drive, and restarted pro tools, it was smooth sailing. Must be confusion in differentiating between two drives of the same name, even though one is local and the other networked.
Hope this helps.
Cheers
Similar thing here but there were 2 local drives with the same name.. ejected one and restarted pro tools and all was good
Thanks for pointing me in the right direction!
Sam
Old 04-27-2016, 06:56 PM
tundra
Guest
Posts: n/a
12.4 / 12.5 this error happens constantly now.
The more info button brings up an Avid Help Window that says THERE IS no Help Available for that error.
Old 04-28-2016, 04:48 AM
There are a couple of possibilities that could cause an aae35 error. One is a bad file name (illegal characters, etc.). The second one is the worst - a drive is failing somehow. I had both of these happen at the same time a couple of years back. The interface board in the external hard drive that held my PT sessions was failing. Got that replaced and it's been fine since.
Jack
QAPLA!
Old 06-22-2016, 10:48 AM
TechTracker TechTracker is offline
I was having the same problem--thanks corym for the fix! I had two drives with same name (one internal and one external). Re-naming one of them fixed the problem and the error message is gone.
  #16
Old 03-09-2017, 08:42 AM
saspro saspro is offline
I got this today after importing a file. Seems it was because I'd recently changed the name of a folder that my session was using for a few added files. Quit, undid the name change I'd made in Finder, restarted recent backup of session, and PT was fine.
  #17
Old 03-09-2017, 04:56 PM
Something else that can pop an aae35 error is if you have two drives mounted with the same name and folder structure. I recently had one when I had both my working session drive and the backup mounted at the same time and was working with a session on the regular working drive. Shut down the backup drive and no problem.
Jack
QAPLA!
  #18
Old 10-10-2017, 09:27 AM
MacDaddy WGAR MacDaddy WGAR is offline
Just had this pop up on an older PT 8.05 session and I am now running PT11. back then the file names could have a / character in it, of course now the OS or PT app doesn't let you do that. So when I went to save session from an 8 to 11 I changed the / to a - but also had to in the name of the folder as well. It didn't like that and it gave me the 35 error when i attempted playback.
I just quit PT and also renamed all the backup session files with the - as well and restarted PT, it couldn't find the audio files at first but then relinked them all. Now PT won't play but I think a reboot will cure that.
Bill Conners
Creative Director
99-5 WGAR/Majic 105.7
Cleveland, OH
H/W Buffer Error (pro tools error -6104) Only 1 audio track running. kieran.mia macOS 1 01-29-2013 01:39 AM
Pro Tools 9 Playback Error Lead to DAE Error 743 Which Lead to A CPU Overload Error EricMulhern macOS 1 11-20-2011 05:39 PM
Scorch store transaction error. You succesfully paid for this score but an error..... deepfriedpizzainbatter Avid Scorch (iOS) Forum 9 11-07-2011 06:08 AM
Error type 10,address error ,illegal error, buss error ,illegal instruction KasticK Pro Tools TDM Systems (Mac) 3 05-14-2003 11:21 AM
Buss error,Address error,ilegal instruction,error type 10 KasticK Pro Tools TDM Systems (Mac) 1 02-08-2003 05:49 PM
