no signal from controller in protools LE 6.9
Hello,
I'm running protools LE 6.9.2 on a Mac OSX powerbook. I've been able to use my m-audio radium perfectly fine with Reason Adapted. When in Protools (with Reason running through Rewire) I'm able to draw out midi and have it play through reason. I can get no signal from my controller. it recognizes the controller, and as far as the reference guide is concerned. Shouldn't there be a way to play my Reason synthesizer with my controller, and record the audio and/or midi info. I've never gotten the controller to do anything in protools. Thanks for any help, tom |
Re: no signal from controller in protools LE 6.9
Make sure your assigning the correct Reason device in the MIDI Output selector.
filosofem
Aaron Mulqueen - 001 HD Native |
I'm pretty sure I am. if I draw out midi, I can change the Midi output and switch between different synthesizers. there is sound coming from reason, controlled by protools. I just can't get the m audio controller to do anything in protools.
MIDI Thru checked?
filosofem
hi. thanks for your help and sorry for the delay,
Midi thru is checked. still nothing. is my only option to record midi in reason, without protools open, and then feed that back into protools later? there's got to be a more direct way. thanks again. tom |
BUMP! I am having the IDENTICAL problem.
MIDI controller is working A-OK with just Reason Adapted open. Open PT, open up ReWire, get the Reason session playing fine. But NO MIDI CONTROL now. Please advise; thanks in advance! -Eric @ Studio Curve Dominant |
i have exactly the same problem. I am running 7.1 and have an axiom 25 controller. I can get sound to come through on the rewired instrument tracks, but i cannot get pro tools to recognize my controller for sequencing. I am completely lost and have spent so much time trying to get this to work. Someone must have an answer.
What does your audio input say? I know, sounds like a dumb question, but some of my older plugins work the same way. I see midi info coming in, but no sound! When I switched the audio input to a physical input on the interface, it started working. FM7 behaved this way, until I just messed around with the configurations. Just a thought.
Good Luck------------- |
This is the case for plugins that are not PT 7.x compatible.
Update your plugins if you can to avoid this.
Getting signal from controller but no sound or playback in Pro tools LE 7 | ach | Pro Tools Express on Mac OS X | 1 | 02-22-2013 01:55 AM |
No Signal From my midi Controller To PT8.0 | V0X | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 1 | 01-22-2009 07:59 PM |
No Midi Signal going from PT to my controller..... | gmg | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 4 | 01-10-2006 03:30 PM |
No midi OUT signal using synth controller | ajgll | MIDI | 0 | 01-26-2004 11:44 PM |
no MIDI signal into digi001 box from controller keyboard... help! | tommydee | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 2 | 02-15-2001 11:47 AM |
