Does M-Powered ilok has License GSM card?
HI,
I just purchased a new package of PTMP. After opening up the package, I didn't find the GSM chip like license card included in it. There is only the usb dongle. However, I still continued the installation, went to www.ilok.com, installed ilokserver. But it says "No iloks were detected.Attach an iLok to an available USB port and try again". I contacted ilok.com, but their reply is: "Please contact Digidesign for further information on their software's authorization methods. Authorization management is handled by the software developers themselves. We at PACE only develop the protection technology chosen by software developers." So I turn to you guys. Is there a chip in your package? or just the dongle? why can't I install? |
Re: Does M-Powered ilok has License GSM card?
The GSM card seems to be already in th iLok (as far as I can see on mine). The M-Powered iLok is pre authorized so you don't need to go to iLok's website to use PTMP. In anyway, I didn't have any pb to register my iLok on the web and the dongle is as it. Is your iLok is on and supplied enough ? (do you use an USB-Hub ?)
Macbook Pro (Core2duo 2,4GHz RAM4GB SSD) MacMini (Core i7 Quad@2,3GHz RAM16GB SSD) PT 10.3.10 + PT12.4 / VEP5.3.1 / MacOSX.9.5 (MBP) PT12.4 / VEP5.3.1 / MacOSX.11.1 (MBP) PT 10.3.10 / PT11.3.2 / PT12.4 / VEP5.3.1 / MacOSX.8.5 (MM "Production" on SSD) PT 12.4 / VEP5.3.1 / MacOSX.11.1 (MM "test" on HDD) RME UFX (USB2 with MM and Firewire with MBP) + Vienna Ensemble Pro Server on PC Q6600/8Gb/Win7-Pro64-SP1 |
I didnt see there is a GSM card inside my dongle, but according to DIGI service center, they say it is pre-authorized. I am running PTMP on my Powerbook G4 17, under OSX 10.4.2, without using any USB hub. However, I tried the both USB plug on PB, neither works.
The green LED on the dongle is always there, but when I start up PTMP, it says "the version of pro Tools requires authorization to run, but no ilok can be found". I did follow the instruction of iLok.com, installed ilok extension and client service... Still don't know what to do with it. |
Is it possible for you to try the iLok in another computer, to verify if it's working or not?
If you can 'synchronize' the iLok (from the iLok website) on another computer, then that indicates there's a problem with your computer and not the iLok itself. |
FS: M Powered 8 ilok License | Zooloolo | Buy & Sell | 2 | 12-30-2014 01:30 AM |
NO iLok License Card with GSM format license chip | willy wonka | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 1 | 04-19-2007 10:26 PM |
ilok license card????????? | Renouf | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 3 | 08-06-2005 03:06 PM |
Got an iLok with no license card | normanvegan | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 2 | 06-24-2004 04:18 PM |
