#121
Re: Sample Rounding Issue!!!!
This issue is worst than the AAE errors. Last week I formatted the partition where PT 11 was running on yosemite because of the drop of the NI (and others) support. PT 11 was unaffected from this error on midi clips and was useful for arranging songs without having to do with this.
Avid HDX - Avid HD I/O 16x16 Analog - Pro Tools Ultimate 2023.6 - Nuendo 11 Mac Pro 5.1 2 esacore 2.66 64GB Ram - Mac OS 11.7.7 |
#122
iMac 27" Late 2013 3.5Ghz i7 32GB Ram 3TB HDD, 1TB SSD Samsung 850 Pro, Movaje 10.14.6, Pro tools 2021.7, 2021.3 & 2020.12 installed. UAD Apollo 8 Quad & Satellite Quad, Reason 10.4.1 & Reason Suite 11.3.9, Logic Pro X 10.5.1 (need to upgrade to Catalina for LPX10.6), plugins & VI's by practically everyone. G-Tech Mini 1TB HDD, 3 x 1TB Glyph GT050Q, Lacie Rugged 500GB & several assorted drives.....lots & lots of hardware synths & outboard https://soundcloud.com/2b3productions |
#123
are you saying that the Sample Rounding is NOT happening in PT11 ??? that it started with PT12 ??? thx for the info
#124
Well, I'm going to say that for me it started when PT started it's transition to full 64 bit (PT11) I have pretty much abandoned MIDI in PT (I do it all in Logic and mix in PT) but the issue also exists in audio and - it may be my imagination - but it seems to be getting worse/more noticeable with each update, don't believe me? try duplicating a clip or region 3 or 4 times on the same track, using command+D parks/shuffles the clip directly behind the original, as I said do it 3 or 4 times, view it in grid mode and then zoom in to the gaps between the clips to how far off the grid the clips are.
Always worked perfectly back in PT 10 and before. |
#125
Btw I' ve never seen this error in PT11 (and older) on midi clips. Yes there is always been on audio material
#126
thx ... and sad
#127
I would try to work at 48khz to see if this is less invasive given that there are some bpm tempo that beats match exactly the sample at 48
#128
It is just ridiculous that PT is still the ONLY DAW where this is the case. We can't be limited to working on projects at specific tempos & sample rates.
#129
This means that you will have exactly 25 samples per ticks. Every tick will fall into a integer sample. Working at 60 bpm you will have 50 samples per tick, while at 240 bpm 12,5 per tick then the issue could show up. I think that a daw shouldn't work in sample base when treating midi material. Midi and instrum tracks work always in sample base, even when set to tick. The only difference is that when set in sample the events remain in a fixed position when changing tempo. Just my thought
#130
1) Pro Tools - began as an AUDIO only platform ... and brought Midi capabilities ... and it is weaker than most in Midi ... 2) Logic, Cubase, etc ... began more as Midi related platforms .. and brought in Audio capabilities ... i cannot say that the other programs are Weak in Audio !! only makes me bummed that i learned Pro Tools 1st .. as it is not as easy to get around Audio in Logic as PT .. and only because i have PT burned into my brain .. a little Electro Shock and i shoud be able to unlearn all this PT crap !! ha ..
Sample Rounding | budda963 | Pro Tools 11 | 1 | 07-08-2013 06:07 AM |
sample rounding error in pro tools 10??? | DarkDayz | Pro Tools 10 | 6 | 11-02-2011 03:22 AM |
PT and Sample Rounding WILL cause Issues when Copying | 25ghosts | Pro Tools TDM Systems (Mac) | 7 | 07-01-2011 02:25 AM |
Sample rounding issues | bigdoghat | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 4 | 11-13-2007 08:20 AM |
Sample rounding, ticks, etc | voce | Pro Tools TDM Systems (Mac) | 1 | 08-03-2005 05:26 AM |
