Go Back   Avid Pro Audio Community > Pro Tools Hardware > FireWire & USB Audio Interfaces (Mac)
Old 05-02-2014, 01:36 AM
kvp kvp is offline
Default Mbox and mbox pro - linking them together
Hello. This might be a stupid question, but here goes: I have the mbox with 2 inputs. Is it possible to use the mbox pro with 4 inputs and connect the two using s/pdif and that way get 6 inputs?
Old 05-12-2014, 07:16 PM
serio serio is offline
Default Re: Mbox and mbox pro - linking them together
if both Mbox and mbox pro drivers can live on the same computer happily, then you should be able to do this. Since the mbox doesnt have a stand alone mode you'll need to have it connected to the computer via usb as well as have it's SPDIF outs connected to the Pro's SPDIF ins. in the Mbox control panel, click the SPDIF out tab. Turn your analog channels 1 and 2 up to unity and now signal will pass freely through the digital outs(you still control gain via the front mbox knobs). if its mono signals you want to feed, then unlink the channels and pan them center. When pro tools is running, you'll want to make sure that the Mbox Pro is the selected hardware device and you'll want to be clocked via SPDIF instead of internally.
Alternatively, you could try making an aggregate device but that's a whole other story and set of instructions.
21.5" Mid-2011 iMac i5 QUAD 2.5GHZ 4G RAM ML 10.8.5--Pro Tools 10.3.9--Avid Mbox Pro / 003R--ICY DOCK MB664UEA-1S FW400 With: 500GB Samsung HD502HJ
SC48 pops when linking or un linking stereo channels lorenaguey VENUE Live Sound Systems 7 07-16-2013 08:11 AM
Digi Tech Suppport? Pfft!!! Mbox/Mbox academic Questions WestPhillySoulzition 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 1 11-17-2008 01:03 PM
Mbox 2 Pro vs Mbox latency - Mbox 2 Mini pro? marcnyc 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 1 11-28-2006 08:18 PM
Linking MBox and 002...can you? Allbaldo 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 0 02-04-2004 05:05 PM
Mbox - Routing the computers audio through the mbox ie. CD Rom, system sounds brownmusic 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 0 01-30-2003 03:22 PM
