Old 03-27-2009, 06:58 AM
TheWillies TheWillies is offline
Default Fresh Install / Serious problems
Hey guys, my computer crashed, and I had to reformat and reinstall everything. Up until it crashed, it ran PT great for a couple years. So, right now PT will only play for 2 seconds before there is some kind of error. I have tried changing the settings PT suggests, but nothing helps. Here is my system report, if anyone can help that would be great, thanks!
http://www.satyenmusic.com/SystemReport.txt
PT 9...Mackie Onyx 800R / Digi 002R...Windows 7 64bit...http://www.myspace.com/satyenmusic
Click here for unlimited ADC
Old 03-27-2009, 09:51 AM
TOM@METRO's Avatar
Default Re: Fresh Install / Serious problems
A Sandra lite report would make this easier,
- Please - Use SiSoftware's Sandra Lite application to generate a full system profile:
~ tom thomas
Formerly hobotom
HD Omni and 192 I/Os
Windows 10
Intel Hexcore i7
All Samsung Pro SSDs
Ampex MM1200 2" 24 trk tape
www.metrostudios.com
Old 03-27-2009, 10:12 AM
shea shea is offline
Actually Its hard to say where to start,there are so many thing.
Creative card has to go, onboard audio disabled, power too low ,requires TI firewire, amonghst many.
seamus
Old 03-27-2009, 10:38 AM
spkguitar's Avatar
"Some kind of error"????
Could you narrow that down please? It would be much easier to help you if you could tell us EXACTLY what error you were getting.
Edit: and I totally agree; if you ran "PT great for a couple of years" with that audigy card in there, you were EXTREMELY lucky.
Old 03-27-2009, 11:17 AM
Thanks for the responses. The errors I have been getting are:
The Operating system held off interrupts for too long. If this occurs frequently, try increasing the "H/W Buffer Size" in the Playback Engine panel (-6088)
Audio processing is conflicting with other CPU tasks. If this occurs often, reducing the "H/W Buffer Size" in the Playback Engine Dialog may help prevent the problem (-9129)
The audio device buffer underflowed. If this occurs frequently, try decreasing the "H/W Buffer Size" in the Playback Engine panel or remove other devices from the audio firewire bus (-6085)
My computer is a Creation Station Tower (2006) from Sweetwater. I did add that Audigy card, and had no problems. If the problems are that many, I might just get a new computer. I think the processor might be bad now too. I transferred a massey plugin file from the computer to my laptop, both zipped and unzipped. The plugin didn't work right when I installed the unzipped one, but when I replaced it with the file from the zipped one, it worked fine. ???
Old 03-27-2009, 01:28 PM
gvees gvees is offline
did you install PT 8 also with the fresh install? Which version of PT did you use before? PT 8 is a lot heavier on system resources...
Old 03-27-2009, 02:03 PM
Thanks for the responses. I think I am just going to get a new computer, I've always wanted a Quad anyway. Thanks.
Old 03-27-2009, 02:22 PM
spkguitar's Avatar
Looks like this link from the digidesign support pages might apply...
Or maybe even this one...
I know you said you had Pro Tools "running great" on that system, but I'm not really sure how, and I will stand by my first statement; you were EXTREMELY lucky. Not only do you have the Audigy, which is known to cause problems with PT, but it has integrated graphics which is a HUGE 'no-no" with Pro Tools.
One thing you might want to try examine is the IRQ assignments.
Old 03-27-2009, 04:39 PM
I've made a lot of recordings with this computer, and I haven't had any problems. I was able to do what I wanted to do. So, I guess I was lucky. But now that luck has run out...I'll check that stuff out, thanks!
Old 03-28-2009, 12:35 AM
Steevp Steevp is offline
I'd made a lot of recordings before PT8 changed my "luck" too..
www.Krankschaft.com
Windows7 64bit, RME UCX, Asus Z97-P, i7-4790K@4.00Ghz, 32GB Ballistix Ram, Console 1, Unity Audio Rocks, RME UCX.
Fresh install...bad, bad, bad.... gofortheheart Windows 5 09-03-2012 03:21 PM
Clean install of PT 10 under fresh install of Lion bortraws macOS 0 10-24-2011 08:53 AM
Fresh Install? carnology 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 3 08-16-2005 04:39 PM
How to install fresh OS? BigALW1414 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 5 11-20-2004 02:05 PM
CPU power problems with fresh XP install. Please help your friend!!! silence_of_stone 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 4 03-19-2003 09:08 AM
