Error 6097 Lost communication again and again!!!! 7.3.1
I have been getting the 6097 messages ever since I've upgraded to 7.3.1. I've recently installed cs2. I've completely reformatted my internal system drive with Tiger and am now running 10.4.9. Things weren’t running much better on 10.4.8. I did get PT 7.3.1 to run with 10.4.8 but was limited to the 512 setting in the H/W playback and 85% in the CPU (in the playback engine) If I switched either of these settings PT would freeze and then start shooting off the 6097 or "problem with internal clock detected" Also in 10.4.8 very time I tried to import audio the system would completly freeze if I chose to have the new audio "start at beginning of the session". The only way I could import audio into a session was to choose "put in regions list" and then pull the audio out to a track manually and try to save the session before it crashed.
Now with 10.4.9 I can't create a new session or open an existing sessions with out getting "6097 lost communication with the audio interface. Please try increasing H/W buffer size or removing plugins and make sure clock source and sample rate are correct" With 10.4.8 I also received all these error codes 6093, 6086, 6085 Here is what I've tried to do to fix the problem: Digit sent a new power harness for the 002 rack, and its been installed. Completely erased my internal system drive and installed a fresh version of Tiger...(version 10.4.9 currently installed) Checked compatibility of all plug ins (the digi bomb factory 7.3 plugs crash my system so I run PT with out them installed. As well NI's Akoustic Piano latest version prevents PT from running even though NI claims that this version works with PT 7 and up. I've run the three plug in compatibility updaters the developing partners, digidesign ect..that were available on the Digi site I've deleted prefs, .coms, plists and databases as directed by the trouble shooting guide. I re-installed from PT 7 to 7.3.1 (a few times) with a clean uninstall Fixed disc permissions with the OSX Disc Utility. I've checked login items in system prefs and start up items in "my user name"/library ect I reset open firmware at computer start up I am not using a PCI Graphics card No Bluetooth My System drive and Audio drives are journaled Air Port is turned off Energy saver is off, no sleep, CPU Highest I run a diagnostic test on my systems Ram and checked Fire wire and other components, they seem to be correct: Built In Sound Card: Devices: Texas Instruments TAS3004: Inputs and Outputs: Line Level Input: Controls: Left, Right Playthrough: No PluginID: TAS Headphones: Controls: Mute, Left, Right PluginID: TAS Internal Speakers: Controls: Mute, Master PluginID: TAS Line Level Output: Controls: Mute, Left, Right PluginID: TAS Crystal Semiconductor CS84xx: Inputs and Outputs: S/PDIF Digital Input: Controls: Mute Playthrough: No PluginID: Topaz S/PDIF Digital Output: Controls: Mute PluginID: Topaz Formats: PCM 16: Bit Depth: 16 Bit Width: 16 Channels: 2 Mixable: Yes Sample Rates: 32 KHz, 44.1 KHz, 48 KHz PCM 24: Bit Depth: 24 Bit Width: 32 Channels: 2 Mixable: Yes Sample Rates: 32 KHz, 44.1 KHz, 48 KHz AC3 16: Bit Depth: 16 Bit Width: 16 Channels: 2 Mixable: No Sample Rates: 32 KHz, 44.1 KHz, 48 KHz GeForce FX 5200: Chipset Model: GeForce FX 5200 Type: Display Bus: AGP Slot: SLOT-1 VRAM (Total): 64 MB Vendor: nVIDIA (0x10de) Device ID: 0x0321 Revision ID: 0x00a2 ROM Revision: 2060 Displays: SyncMaster: Resolution: 1280 x 1024 @ 60 Hz Depth: 32-bit Color Core Image: Supported Main Display: Yes Mirror: Off Online: Yes Quartz Extreme: Supported SyncMaster: Resolution: 1280 x 1024 @ 60 Hz Depth: 32-bit Color Core Image: Supported Mirror: Off Online: Yes Quartz Extreme: Supported DIMM0/J11: (thru 4 have same message) Size: 256 MB Type: DDR SDRAM Speed: PC3200U-30330 Status: OK FireWire Bus: Maximum Speed: Up to 800 Mb/sec Digi 002Rack: Manufacturer: Digidesign Model: 0x2 GUID: 0xA07E0000A40000 Maximum Speed: Up to 400 Mb/sec Connection Speed: Up to 400 Mb/sec Sub-units: Digi 002Rack Unit: Unit Software Version: 0x1 Unit Spec ID: 0xA4 NO PCI CARD Is there any hope that this system will work. Please help me find out what is wrong Between my G5 and Pro Tools!!! |
Re: Error 6097 Lost communication again and again!!!! 7.3.1
Oh yeah here is my general system
Mac PowerPC G5 1.8Ghz 1 Gig ram OSX 10.4.9 Digi 002 rack PT 7.3.1cs2 |
Did you load the COMBO updater for 10.4.9?
Park The Transfer Lab at Video Park Analog tape to Pro Tools transfers, 1/4"-2" http://www.videopark.com MacPro 6 core 3.33 GHz, OS 10.12.1, 8 GB RAM, PT12.6.1, Focusrite Saffire Pro 40, PreSonus DigiMax, MC Control V3.5, dual displays, Neumann U-47, Tab V76 mic pre, RCA 44BX and 77DX, MacBook Pro 9,1, 2.3 Mhz, i7, CBS Labs Audimax and Volumax. Ampex 440B half-track and four-track, 351 tube full-track mono, MM-1100 16-track. |
What is COMBO update
Apple: MBP 2.53 - 4G RAM HDD 500G, iMac 27 inch 1TB ProFire 2626, MBox Micro, PTMP 8, NIs, Strike, POD Farm, Logic 9, EJ Strat, 52 Tele RI, MB Mk 3, PRS CE22, Epi Casino, PBass, Variax, L6XTL, M13, DRRI, BM iGuitar, GR-33, KeyStation 88, Axiom 49 |
Do you mean the combo updater from apple? ...I'm not sure I'll check. At the time that I intstalled 10.4.9 my Mac did it instantly as a "software update".
Ah! Then you don't have the right updater. Go to Apple and find the Combo Updater for 10.4.9.
Then, turn off the auto update. Check with Digi before loading any update. 10.4.9 is not approved but the Combo Updater seems to work. I am still at 10.4.8, however.
Any idea why in 10.4.8 I could'nt use the 1024 sample setting and be able to increase cpu from %85 (in the playback engine panel) with out a total freeze. And a freeze with importing audio as well?
Thoughts?? |
Can anybody help with this problem???
I've just bought an 002R this week and it's been working fine, today i received my first "lost connection" error message. It was triggered because i had the 002R set as my internal audio output, i had Pro Tools launched and when i went to launch iTunes thinking it would auto default to internal audio the message popped up. The session started playing back no probs and itunes came through default audio. Not sure what happened......core audio being as reliable as ever i guess.
Do you have the 002 as your default audio and is something trying to access this when your using Pro Tools, messenger, itunes, mail etc? Cheers
iMac i5 2.8GHz, Macbook Pro 2.4GHz, Pro Tools 10/11, MOTU 828mk2, Presonus Digimax FS, Presonus Firestudio Project, TC Konnekt 24D --- iCON Photography |
hey pwmachine -
do you use cracked/outdated plug-ins or anything along those lines? those cause 6097 if you search the duc you will find others with that same problem. Getting error messages in Pro Tools in OS X: -6086, -6093, - 6097. Setting the CPU Usage Limit above 95% may cause -6086, -6093, or -6097 errors. If a -6097 error occurs while Pro Tools is idle, reduce the number of plug-ins active in the current session. otherwise there have been a rash of FireWire port problems with many G5's and latest Mac's if you read up on Apples forums/support section. much less "false" DAE errors and embarrsement in front of clients. PT won't let you record drop outs into the audio and thus is very sensitive to any issues on your system. My Mac Pro that I just got for my editing room has already strange 1394 issues... so I contacted apple and it's not a new issue to them! wtf? time again I'm thankful for my Siig card which always seems to work better than the built in ones. (They now have a PCIe version that works and is supported too, so you should be able to get one and never look back.) Best of luck man. |
Lost Communication -Error -6097/Pro Tools and 4 Processors | Boogie457 | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 1 | 05-20-2010 08:18 AM |
Lost Communication -Error -6097/Pro Tools and 4 Processors/ | Boogie457 | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 2 | 05-20-2010 08:07 AM |
Lost communication(-6097)......HELP.... | dope.as.one | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 0 | 02-13-2009 09:06 PM |
Lost communication with the audio interface. error 6097 | Ian! | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 7 | 04-11-2008 03:48 PM |
Lost communication with the 002 unit (-6097) | Lethanir | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 1 | 11-24-2006 06:43 PM |
